How can I use async webpage with esp32 from both wifi and ethernet? How can I combine it with EthernetWebServer?
I want to access the esp32 aync webpage from both ethernet and wifi. my code works fine with wifi :
#include <WiFi.h>
#include <WebServer.h>
#include "ESPAsyncWebServer.h"
#include <AsyncTCP.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
const char* ssid     = "ssid11";
const char* password = "password123";
const char* PARAM_INPUT_1 = "output";
const char* PARAM_INPUT_2 = "state";
AsyncWebServer server(8081);
#define DHTPIN 14
// Uncomment the type of sensor in use:
#define DHTTYPE    DHT11     // DHT 11
DHT dht(DHTPIN, DHTTYPE);
String readDHTTemperature() {
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  if (isnan(t)) {
    Serial.println("Failed to read from DHT sensor!");
    return "--";
  else {
    Serial.println(t);
    return String(t);
String readDHTHumidity() {
  float h = dht.readHumidity();
  if (isnan(h)) {
    return "--";
  else {
    Serial.println(h);
    return String(h);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <title>ESP32 Web Server</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
  <link rel="icon" href="data:,">
  <style>
    html {font-family: Arial; display: inline-block; text-align: center;}
    p { font-size: 1.2rem;}
    body {margin:0px auto; padding-bottom: 20px;}
    .topnav { overflow: hidden; background-color: #50B8B4; color: white; font-size: 1rem; }
    .content { padding: 20px; }
    .card { background-color: white; box-shadow: 2px 2px 12px 1px rgba(140,140,140,.5); }
    .cards { max-width: 800px; margin: 0 auto; display: grid; grid-gap: 2rem; grid-template-columns: repeat(auto-fit, minmax(200px, 1fr)); }
    .reading { font-size: 1.4rem; }
    .switch {position: relative; display: inline-block; width: 120px; height: 42px}
    .switch input {display: none}
    .slider {position: absolute; top: 0; left: 0; right: 0; bottom: 0; background-color: #ccc; border-radius: 6px}
    .slider:before {position: absolute; content: ""; height: 26px; width: 26px; left: 8px; bottom: 8px; background-color: #fff; -webkit-transition: .6s; transition: .6s; border-radius: 3px}
    input:checked+.slider {background-color: #505843}
    input:checked+.slider:before {-webkit-transform: translateX(52px); -ms-transform: translateX(75px); transform: translateX(75px)}
  </style>
</head>
 <body>
   <div class="topnav">
    <h1>ESP-32 WEB SERVER</h1>
  </div>
  <div class="content">
    <div class="cards">
      <div class="card">
        <p> <i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
    <span class="dht-labels">Temperature</span>
    <span id="temperature">%TEMPERATURE%</span>
    <sup class="units">&deg;C</sup></p>
      </div>
      <div class="card">
        <p>  <i class="fas fa-tint" style="color:#00add6;"></i>
    <span class="dht-labels">Humudity</span>
    <span id="humidity">%HUMIDITY%</span>
    <sup class="units">&percnt;</sup>
        </p>
      </div>
    </div>
  </div>
   %BUTTONPLACEHOLDER%
<script>function toggleCheckbox(element) {
  var xhr = new XMLHttpRequest();
  if(element.checked){ xhr.open("GET", "/update?output="+element.id+"&state=1", true); }
  else { xhr.open("GET", "/update?output="+element.id+"&state=0", true); }
  xhr.send();
</script>
</body>
<script>
setInterval(function ( ) {
  var xhttp = new XMLHttpRequest();
  xhttp.onreadystatechange = function() {
    if (this.readyState == 4 && this.status == 200) {
      document.getElementById("temperature").innerHTML = this.responseText;
  xhttp.open("GET", "/temperature", true);
  xhttp.send();
}, 5000 ) ;
      document.getElementById("humidity").innerHTML = this.responseText;
  xhttp.open("GET", "/humidity", true);
  xhttp.send();
}, 5000 ) ;
</script>
</html>
)rawliteral";
String outputState(int output){
  if(digitalRead(output)){
    return "checked";
  else {
    return "";
String processor(const String& var){
  //Serial.println(var);
     if(var == "BUTTONPLACEHOLDER"){
    String buttons = "";
    buttons += "<h4>Output - GPIO 15</h4><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"15\" " + outputState(15) + "><span class=\"slider\"></span></label>";
    return buttons;
  else if(var == "TEMPERATURE"){
    return readDHTTemperature();
  else if(var == "HUMIDITY"){
    return readDHTHumidity();
  return String();
void setup(){
  // Serial port for debugging purposes
  pinMode(15, OUTPUT);
  digitalWrite(15, LOW);
  dht.begin();
  // Connect to Wi-Fi STATION
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi..");
  // Print ESP32 Local IP Address
  // Route for root / web page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html, processor);
   // Send a GET request to <ESP_IP>/update?output=<inputMessage1>&state=<inputMessage2>
  server.on("/update", HTTP_GET, [] (AsyncWebServerRequest *request) {
    String inputMessage1;
    String inputMessage2;
    // GET input1 value on <ESP_IP>/update?output=<inputMessage1>&state=<inputMessage2>
    if (request->hasParam(PARAM_INPUT_1) && request->hasParam(PARAM_INPUT_2)) {
      inputMessage1 = request->getParam(PARAM_INPUT_1)->value();
      inputMessage2 = request->getParam(PARAM_INPUT_2)->value();
      digitalWrite(inputMessage1.toInt(), inputMessage2.toInt());
    else {
      inputMessage1 = "No message sent";
      inputMessage2 = "No message sent";
    Serial.print("GPIO: ");
    Serial.print(inputMessage1);
    Serial.print(" - Set to: ");
    Serial.println(inputMessage2);
    request->send(200, "text/plain", "OK");
  server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/plain", readDHTTemperature().c_str());
  server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/plain", readDHTHumidity().c_str());
  // Start server
  server.begin();
void loop(){
In this library a simple web page is accessed over ethernet (using enc28j60) and wifi.
#include "defines.h"
#include <WiFi.h>
#include <SPI.h>
#include <EthernetWebServer.h>
const char* ssid     = "your_ssid";
const char* password = "your_password";
EthernetWebServer ethernetServer(80);
WebServer wifiServer(80);
const int led = 13;
void handleEthernetRoot()
  ethernetServer.send(200, "text/plain", "Hello from ESP32 Ethernet!");
void handleWiFiRoot()
  wifiServer.send(200, "text/plain", "Hello from ESP32 WiFi!");
  Serial.println("\nStarting WiFi_Ethernet_Complex_ESP32 on " + String(ARDUINO_BOARD));
  Serial.print("Connecting to ");
  Serial.println(ssid);
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
#if USE_ETHERNET_GENERIC
  ET_LOGWARN(F("=========== USE_ETHERNET_GENERIC ==========="));
#elif USE_ETHERNET_ESP8266
  ET_LOGWARN(F("=========== USE_ETHERNET_ESP8266 ==========="));
#elif USE_ETHERNET_ENC
  ET_LOGWARN(F("=========== USE_ETHERNET_ENC ==========="));
#else
  ET_LOGWARN(F("========================="));
#endif
  ET_LOGWARN(F("Default SPI pinout:"));
  ET_LOGWARN1(F("MOSI:"), MOSI);
  ET_LOGWARN1(F("MISO:"), MISO);
  ET_LOGWARN1(F("SCK:"),  SCK);
  ET_LOGWARN1(F("SS:"),   SS);
#if defined(ESP8266)
  // For ESP8266, change for other boards if necessary
#ifndef USE_THIS_SS_PIN
#define USE_THIS_SS_PIN   D2    // For ESP8266
#endif
  ET_LOGWARN1(F("ESP8266 setCsPin:"), USE_THIS_SS_PIN);
#if ( USE_ETHERNET_GENERIC || USE_ETHERNET_ENC )
  // For ESP8266
  // Pin                D0(GPIO16)    D1(GPIO5)    D2(GPIO4)    D3(GPIO0)    D4(GPIO2)    D8
  // Ethernet           0                 X            X            X            X        0
  // Ethernet2          X                 X            X            X            X        0
  // Ethernet3          X                 X            X            X            X        0
  // EthernetLarge      X                 X            X            X            X        0
  // Ethernet_ESP8266   0                 0            0            0            0        0
  // D2 is safe to used for Ethernet, Ethernet2, Ethernet3, EthernetLarge libs
  // Must use library patch for Ethernet, EthernetLarge libraries
  Ethernet.init (USE_THIS_SS_PIN);
#elif USE_CUSTOM_ETHERNET
  // You have to add initialization for your Custom Ethernet here
  // This is just an example to setCSPin to USE_THIS_SS_PIN, and can be not correct and enough
  Ethernet.init(USE_THIS_SS_PIN);
#endif  //( USE_ETHERNET_GENERIC || USE_ETHERNET_ENC )
#elif defined(ESP32)
  // You can use Ethernet.init(pin) to configure the CS pin
  //Ethernet.init(10);  // Most Arduino shields
  //Ethernet.init(5);   // MKR ETH shield
  //Ethernet.init(0);   // Teensy 2.0
  //Ethernet.init(20);  // Teensy++ 2.0
  //Ethernet.init(15);  // ESP8266 with Adafruit Featherwing Ethernet
  //Ethernet.init(33);  // ESP32 with Adafruit Featherwing Ethernet
#define USE_THIS_SS_PIN   5   //22    // For ESP32
#endif
  ET_LOGWARN1(F("ESP32 setCsPin:"), USE_THIS_SS_PIN);
  // For other boards, to change if necessary
  // ESP32 => GPIO2,4,5,13,15,21,22 OK with Ethernet, Ethernet2, EthernetLarge
  // ESP32 => GPIO2,4,5,15,21,22 OK with Ethernet3
  //Ethernet.setCsPin (USE_THIS_SS_PIN);
#endif    //defined(ESP8266)
  // start the ethernet connection and the server:
  // Use DHCP dynamic IP and random mac
  uint16_t index = millis() % NUMBER_OF_MAC;
  // Use Static IP
  //Ethernet.begin(mac[index], ip);
  Ethernet.begin(mac[index]);
  // Just info to know how to connect correctly
  Serial.println("=========================");
  Serial.println("Currently Used SPI pinout:");
  Serial.print("MOSI:");
  Serial.println(MOSI);
  Serial.print("MISO:");
  Serial.println(MISO);
  Serial.print("SCK:");
  Serial.println(SCK);
  Serial.print("CS/SS:");
  Serial.println(USE_THIS_SS_PIN);
  Serial.println(F("========================="));
  Serial.print(F("Using mac index = "));
  Serial.println(index);
  ethernetServer.on("/", handleEthernetRoot);
  ethernetServer.begin();
  Serial.print(F("HTTP EthernetWebServer is @ IP : "));
  Serial.println(Ethernet.localIP());
  wifiServer.on("/", handleWiFiRoot);
  wifiServer.begin();
  Serial.print(F("HTTP WiFiWebServer is @ IP : "));
  // listen for incoming clients
  ethernetServer.handleClient();
  wifiServer.handleClient();
WiFi_Ethernet_Complex_ESP32.ino
I want to access the web page from both ethernet and wifi using this library. How can I combine the two codes?
Libraries:
defines.h
EthernetWebServer
ESPAsyncWebServer
