How can i use Nunchuck with arduino micro
Hi everyone !
I recently own a wiichuck adaptateur and a nunchuck, but even with all google research i've made, im still searching for an arduino code/library to make nunchuck work with my arduino micro. I don't know how to plug the wiichuck too, i try almost everything, but i can only find the UNO way to plug it, witch don't work for arduino micro.
Thanks for anwser.
A quick Google search for "arduino nunchuck" brings up several hits. Maybe start with these http://www.instructables.com/id/Wii-Nunchuck-as-general-purpose-controller-via-Ard/?ALLSTEPS and http://www.gabrielbianconi.com/projects/arduinonunchuk/
Thanks for answer. My research already bring me to your links, where only arduino Uno/Due is used, witch don't work for my micro. No one have a Arduino micro and have working nunchuck ?
wanted110: My research already bring me to your links, where only arduino Uno/Due is used, witch don't work for my micro. No one have a Arduino micro and have working nunchuck ?
You communicate with the Nunchuck using SDA/SCL that are on pins D2/D3 respectfully on the Micro. Though I don't have a Micro I assume that following any UNO tutorial but substituting A4/A5 wiring for D2/D3 would work.
wanted110: You communicate with the Nunchuck using SDA/SCL that are on pins D2/D3 respectfully on the Micro. Though I don't have a Micro I assume that following any UNO tutorial but substituting A4/A5 wiring for D2/D3 would work.
A4/A5, switched to D2/D3 -> BRILLANT ! IT WORK :p Thanks a lot !! :)
