How can I use serial communication between my esp32 cam once it has detected an object to ask a UNO r3 to do something?
Question/Issue:
How do I make my esp32 cam command my uno r3 to move motors through serial communication after the esp 32 cam has detected an object above 0.995 confidence for 3 times in a row?(Hardware and Software issue)
Project ID(From Edge Impulse):
601271
Context/Use case:
So my esp-32 cam is recognizing what it’s supposed to recognize pretty easily, but once it has detected something for 0.995 and above confidence for 3 times in a row, I tried to code it to communicate to the arduino to move some motors, however the code just stops working.
Steps Taken:
  1. I tried to do simple serial communication through a youtube tutorial, although the esp32 cam was saying hello and arduino saying message received they did not come up in the same serial monitor, just in the same baud rate but not in the same serial monitors. I should also mention that the esp 32 cam and arduino were in different ports.
  2. I tried a bunch of different schematics online to connect the esp 32 and arduino directly to see if it was a hardware issue in terms of connectivity, but the functionality of the aforementioned program was worse, the arduino was working saying hello, but my esp32 stop saying message received.
  3. I tried using ChatGPT to code for me for the original project but as always it didn’t work, this step was a done in a bit of frustration.
Expected Outcome:
Esp-32 cam detects something for 0.995 and above confidence 3 times in a row → arduino starts moving motors and executes the program.
Actual Outcome:
program stops working entirely
Reproducibility:
  • [ ] Always
Environment:
  • Platform: [Uno R3]
  • Build Environment Details: [e.g., Arduino IDE 1.8.19 ESP32 Core for Arduino 2.0.4]
  • OS Version: [Windows 11]
  • Edge Impulse Version (Firmware): [e.g., 1.2.3]
  • To find out Edge Impulse Version:
  • if you have pre-compiled firmware: run edge-impulse-run-impulse --raw and type AT+INFO. Look for Edge Impulse version in the output.
  • if you have a library deployment: inside the unarchived deployment, open model-parameters/model_metadata.h and look for EI_STUDIO_VERSION_MAJOR, EI_STUDIO_VERSION_MINOR, EI_STUDIO_VERSION_PATCH
  • Edge Impulse CLI Version: [e.g., 1.5.0]
  • Project Version: [1.0.2]
Esp-32 cam code:
// Include necessary headers
#include <Arduino.h>
// Add global variables
const float CONFIDENCE_THRESHOLD = 0.995;
const int REQUIRED_CONSECUTIVE_DETECTIONS = 3;
int detection_count = 0;
String last_detected_label = “”;
// Initialize serial communication with Arduino
Serial1.begin(9600); // For communication with Arduino Uno
while (!Serial);
Serial.println(“Edge Impulse Inferencing Demo”);
if (ei_camera_init() == false) {
    ei_printf("Failed to initialize Camera!\r\n");
    ei_printf("Camera initialized\r\n");
ei_printf("\nStarting continuous inference in 2 seconds...\n");
ei_sleep(2000);
if (ei_sleep(5) != EI_IMPULSE_OK) {
return;
snapshot_buf = (uint8_t*)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);
if (snapshot_buf == nullptr) {
    ei_printf("ERR: Failed to allocate snapshot buffer!\n");
    return;
ei::signal_t signal;
signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT;
signal.get_data = &ei_camera_get_data;
if (ei_camera_capture((size_t)EI_CLASSIFIER_INPUT_WIDTH, (size_t)EI_CLASSIFIER_INPUT_HEIGHT, snapshot_buf) == false) {
    ei_printf("Failed to capture image\r\n");
    free(snapshot_buf);
    return;
ei_impulse_result_t result = { 0 };
EI_IMPULSE_ERROR err = run_classifier(&signal, &result, debug_nn);
if (err != EI_IMPULSE_OK) {
    ei_printf("ERR: Failed to run classifier (%d)\n", err);
    return;
// Process object detection results
for (uint32_t i = 0; i < result.bounding_boxes_count; i++) {
    ei_impulse_result_bounding_box_t bb = result.bounding_boxes[i];
    if (bb.value >= CONFIDENCE_THRESHOLD) {
        if (last_detected_label == bb.label) {
            detection_count++;
            last_detected_label = bb.label;
            detection_count = 1; // Reset count for a new label
        if (detection_count >= REQUIRED_CONSECUTIVE_DETECTIONS) {
            Serial1.println("ACTIVATE_MOTOR"); // Signal to Arduino
            detection_count = 0; // Reset detection count
free(snapshot_buf);
Uno R3 code:
UNO R3 code:
#include <Servo.h> // Example for controlling servos
Servo motor1; // Define motors
Servo motor2;
Serial.begin(9600); // Communication with ESP32-CAM
motor1.attach(9); // Attach motors to pins
motor2.attach(10);
if (Serial.available() > 0) {
String message = Serial.readStringUntil(‘\n’);
    if (message == "ACTIVATE_MOTOR") {
        activateMotors();
void activateMotors() {
// Example motor movement havent gotten past the esp32 cam being able to properly communicate
motor1.write(90); // Rotate motor 1
motor2.write(180); // Rotate motor 2
delay(1000); // Hold for 1 second
motor1.write(0); // Reset motors
motor2.write(0);
Im still very new to coding and arduino in general, so I don't know if its a hardware or software problem. I've only gotten this far for my project due to resources on the internet, so help is very much appreciated.
Your topic does not seem to indicate an upload problen and therefore has been moved to a more suitable location on the forum.
Thanks for using code tags inn your first post :+1:
which specific ESP32-CAM are you using? give a link
which pins are you using for Serial1?
I am doing TX(Esp) to RX and RX(Esp) to TX for Serial and Serial1. The problem is I can't even get it to communicate properly with the arduino when wired together its neither powered or communicates in the same serial monitor.(I have to open a separate serial monitor, although they still do communicate on the same baud, I've tested it with the arduino saying hi, and the cam saying hello).
Logic level shifters are required when connecting I/O pins on 3.3V devices (e.g. ESP32) to I/O pins on 5V devices (e.g. Uno). These are bidirectional. Failure to do so can cause major malfunctions and possibly damage to the I/O pins.
For reliable communications between MCUs, have a look at the Serial Input Basics tutorial.
In order to make all relevant information available to any who are interested in this subject, I'll share a link to the related discussion here:
