How can i use subvariables?
Quick question... how would one go about storing a set of variables in a subvariable... probably the wrong terminology for it.
so for example...
I want to store an
X coord
Y coord
Width
Height
Under a set...
Like if i were to call
button1.X
and have it return the X value
Hello,
Use a struct, or a class :slight_smile:
http://www.cplusplus.com/doc/tutorial/structures
http://www.cplusplus.com/doc/tutorial/classes
2 ways.
A "struct". This is the older C way, but often still appropriate.
A "class". This is the newer C++ way. The door to the world of object orientation.
In a struct, they are normally referred to as "fields". In a class, they are called "attributes".
The difference between 'struct' and 'class' is that until otherwise stated, members are 'public:' in struct and 'private:' in class. If you use a class, put the line "public:" at the top so code outside the class declaration can use the data.
class rectangle {
   public:
        rectangle(int inX,int inY,int inWm int inH);
        ~rectangle(void);
   int X coord;
   int Y coord;
   int Width;
   int Height;
And you just opened up Pandora's box..
Welcome to c++
-jim lee
jimLee:
class rectangle {
public:
        ~rectangle(void);
int X coord;
  int Y coord;
  int Width;
  int Height;
Welcome to c++
-jim lee
THANK YOU!
Ive been playing with arduino and x for a long time now... but have never needed a structure... it helps to know the proper term lol
johnwasser:
Huh... thanks for the tip... thats actually really helpful to know
guix:
Hello,
Yes! Knowledge links!!
I... probably should have thought of looking in the programming base instead of exclusively on arduino lol...
THANK YOU!!
But not until you fix the missing comma
Well, m is close to a comma.
-jim lee
jimLee:
-jim lee
Close enough for jazz :slight_smile:
UKHeliBob:
"Nice!..."
PaulRB:
"Nice!..."
Fast Show reference?
Yes, but of course I was very, very drunk.
