int temp;
how can i write to eeprom the content of temp? what if it has more than 1 digit? for example "123" does the code need to split to 1,2,3 and write to 3 adresses?
int temp;
123 is less than 255 which is the largest value you can store in a byte. However "123" is a string and takes up four bytes.
yeah mistake i mean 123 not "123"
but what about 654? and what is the syntax to do that? do i need to split it and write 6,5,4 in 3 addresses? and how can i join them?(on reading)
int x = 645;
byte hix = highByte (x);
byte lox = lowByte (x);
int x = 645;
thanks for that, a little explain? :-? what value will have the hix and what the lox on this example?
mmm is the split of 645 in 2 bytes?
searching on the internet i saw this elocity = -200 = hex FF38 = [hex FF] [hex 38] = [255] [56] Radius = 500 = hex 01F4 = [hex 01] [hex F4] = [1] [244]
so i think i undestand now..
and another question. do i need to check a demical if it is >than 256 to use high/low fuction before i save it to eeprom? and how do i know when i read from eeprom if the value have 1 or 2 addreesses? if i read always 2 adresses then if the number i saved was less than 256 i'll get wrong result
and how i merge them? ;)
(hix * 256) + lox
Integers have no decimal point.
and how do i know when i read from eeprom if the value have 1 or 2 addresses?
eeproms only directly write or read to byte addresses, so you always have to write or read two bytes to save or retrieve a integer number no matter what it’s value is.
if i read always 2 addresses then if the number i saved was less than 256 i’ll get wrong result
No you will get correct results (even if <256) if you use AWOL’s formula, x= (hix * 256) + lox;
Lefty
search for eepromwriteanything.
Mowcius
