I had a very similar problem with Serial.parseInt() taking much longer to execute than anticipated and changing the baud rate from 9600 made no discernible difference. I was sending commands to the Arduino from a Python program (to either reset an attached bn0O55 gyroscope or to send the current yaw). By replacing
command = Serial.parseInt();
with
command = Serial.read() - '0';
the time lapse between sending the command and receiving a response became negligible. This will only work if the command is a single integer between 0 and 9. The reason for the - '0' is explained nicely in this video: Tutorial 06 for Arduino: Serial Communication and Processing - YouTube at around 3:29.
Have a look at the examples in Serial Input Basics - simple reliable non-blocking ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
Serial.begin(115200); // set serial monitor line ending
// to new line
// if there's any serial available, read it:
while (Serial.available() > 0)
// look for the next valid integer in the incoming serial stream:
int tmp = Serial.parseInt();
// look for the newline. That's the end of your sentence:
if (Serial.read() == '\n'){} // kills 1 second wait
Serial.println(tmp);
