How can parse answer from server?
Hello.
When i send Get to my server respond this:
HTTP/1.1 200 OK
Date: Fri, 31 Jan 2020 23:26:41 GMT
Server: Apache/2.4.41 (Win64) OpenSSL/1.1.1c PHP/7.4.1
X-Powered-By: PHP/7.4.1
Content-Length: 107
Content-Type: text/html; charset=UTF-8
Connection: close
|valnMin=1|valnN1=1|valnN2=0|valnMax=1|valnAlarma=0|valestadoB1=0|valestadoB2=0|valordenB1=0|valordenB2=0|
How can i save all this on a variable?
Ans how can i parse one variable to one value?
Example:
valnMin = 1
valnN1 = 1
valnN2 = 0
etc...
Thx very much ^^
If it is your server, a key thing to do is to send the data in a format that is easy to parse. Packet start/end markers, data delimiters, and timing can be used. If you use the forum search for "parse data" and similar, you will probably find many different methods.
You might be able to use something similar to the below using the "|" as a packet delimiter.
//zoomkat 11-12-13 String capture and parsing
//from serial port input (via serial monitor)
//and print result out serial port
//copy test strings and use ctrl/v to paste in
//serial monitor if desired
// * is used as the data string delimiter
// , is used to delimit individual data
String readString; //main captured String
String angle; //data String
String fuel;
String speed1;
String altitude;
int ind1; // , locations
int ind2;
int ind3;
int ind4;
  Serial.println("serial delimit test 11-12-13"); // so I can keep track of what is loaded
  //expect a string like 90,low,15.6,125*
  //or 130,hi,7.2,389*
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == '*') {
      //do stuff
      Serial.print("captured String is : ");
      Serial.println(readString); //prints string to serial port out
      ind1 = readString.indexOf(',');  //finds location of first ,
      angle = readString.substring(0, ind1);   //captures first data String
      ind2 = readString.indexOf(',', ind1+1 );   //finds location of second ,
      fuel = readString.substring(ind1+1, ind2+1);   //captures second data String
      ind3 = readString.indexOf(',', ind2+1 );
      speed1 = readString.substring(ind2+1, ind3+1);
      ind4 = readString.indexOf(',', ind3+1 );
      altitude = readString.substring(ind3+1); //captures remain part of data after last ,
      Serial.print("angle = ");
      Serial.println(angle);
      Serial.print("fuel = ");
      Serial.println(fuel);
      Serial.print("speed = ");
      Serial.println(speed1);
      Serial.print("altitude = ");
      Serial.println(altitude);
      readString=""; //clears variable for new input
      angle="";
      fuel="";
      speed1="";
      altitude="";
    else {
      readString += c; //makes the string readString
If you're trying to communicate with a server, the standard is to use JSON responses. It already takes care of the delimiting mentioned in the previous replies.
Have you ever wanted to integrate a 3rd Party Client with your SashiDo applications? I suppose you have, and there's an awesome feature called WebHooks which help you do just that. In simple terms, a WebHook allows any 3rd Party Client, that supports Webhooks check myprepaidcenter balance
what are you using, an UNO with an ETH shield or any kind of ESP8266?
read character by character until a linefeed in a buffer.
check if you have an "empty" line - this will be the marker between the HTTP-header and HTTP-body.
if it was a line of the HTTP-header throw it away and start again reading the next line
it it was a line of the HTTP-body use the linebuffer in the next step to parse your data.
you should read about
strtok
at the moment no much luck..
I am trying with this :
  if (cadena2.indexOf("val") > 0)
    String dnMin, dnN1, dnN2, dnMax, dnAlarma, dvalestadoB1, dvalestadoB2, dvalordenB1, dvalordenB2;
    int ind1, ind2, ind3, ind4;
    ind1 = cadena2.indexOf('|');
    ind2 = cadena2.indexOf("|","|");
    dnMin = cadena2.substring(ind1+1, 10);
    dnN1 = cadena2.substring(ind2);
    Serial.println(dnMin);
    Serial.println(dnN1);
    cadena2 = "";
Need parse this:
|valnMin=0|valnN1=0|valnN2=0|valnMax=0|valnAlarma=0|valestadoB1=0|valestadoB2=0|valordenB1=0|valordenB2=0|
only work the fist one...
answer:
valnMin=0
That response would be absolutely trivial to parse using strtok - much simpler than using dozens of subString and indexOf calls. Google "c strtok()".
Regards,
Ray L.
well to trying with that :
    char buf;
    unsigned int len;
    cadena2.toCharArray(buf, len);
    //    dnMin = strtok(buf, '|');
    //    dnN1 = strtok(buf, '|');
    char *strings[10];
    char *ptr = NULL;
    byte index = 0;
    ptr = strtok(buf, '|');  // takes a list of delimiters
    while (ptr != NULL)
      strings[index] = ptr;
      index++;
      ptr = strtok(NULL, '|');  // takes a list of delimiters
    Serial.println(index);
    // print the tokens
    for (int n = 0; n < index; n++)
      Serial.println(strings[n]);
but dont print nothing, to see if are working or no…
and was need convert String to char first…
No progresion atm :frowning:
i think, programming are not my …
A problem with the below data format is there appears to be no start or end markers for the data packet, if this is a data packet. The ease of data capture and parsing may depend on several things. The issue will probably be the same using Strings, or C-strings. Do you have any control over how the data is packaged and the timing of the sending?
...or use JSON
Power_Broker:
...or use JSON
So you got example code? Just curious.
Several problems with that code snippet.
First, you do NO checking that buf is large enough, before copying to it. You are very likely clobbering your memory, right off the bat.
Second, you do not initialize len but pass it as a parameter to toCharArray, so who knows what the result of executing that line is. Again, you are very likely clobbering your memory, right off the bat.
Third, I've never used Strings, and suspect toCharArray() copies the characters, but NOT the trailing NULL that marks the end of the c-style string. So, strtok has no way of knowing where the end of the input string is.
Instead of String.toCharArray(), you should be using String.c_str().
Fourth, you do NO checking that strings contains enough pointers to holds all the tokens strtok parses from the input string.
Regards,
Ray L.
I finally do ti with that:
but i dont sure if are correct, but it work:
    //String dnMin, dnN1, dnN2, dnMax, dnAlarma, dvalestadoB1, dvalestadoB2, dvalordenB1, dvalordenB2;
    int posc = 0; //posicion de cadena2
    int posa = 0; //la posicion del caracter dentro de array dvalores (desde 0 a 8 = 9 )
    memset(dvalores, '\0', 9); //inicializacion del array
    while (posc <= cadena2.length() && posa <= 8)                      //bucle mientras que sea menor que la logitud de cadena2
      while (cadena2.charAt(posc) != '=' and posc <= cadena2.length()) //bucle bsuca el = dentro de cadena2
        //Serial.println(cadena2[posc]);
        posc++;                                                        //suma uno al contador
      if (posc <= cadena2.length())                                    //si no es el final de cadena2...
        dvalores[posa] = cadena2.charAt(posc + 1) - '0';               //guarad el siguiente valor al = en dvalores
        posa++;
        posc++;
    Serial.print("Valores Finales: ");
    for (int c = 0; c <= 8; c++)                                  //mostrar resultados //mientras (inicializacion; condicion de terminar; suma uno por cada loop)
      Serial.print(dvalores[c]);
    Serial.print("\r\n");
    cadena2 = "";
tell my plz is see something wrong
