How can switch betwin two loop usinig one button?
hi everyone
i need to do test about run one program loop i using multiple function but im not success to what i want
my idea is run one loop and when i need cancel the first loop running i will pushing on the same button for run another small loop
like "lave line" when you push the button cancel "pump" run for leave water out about 30 second and finish
and one third problem i need to do another thing when the loop run an led blinking all time except finishing loop
my program i like that :
#include <ezButton.h>
#define LOOP_STATE_STOPPED 0
#define LOOP_STATE_STARTED 1
ezButton button(2);  // create ezButton object that attach to pin 2;
ezButton button1(3); // create ezButton object that attach to pin 3;
ezButton button2(4); // create ezButton object that attach to pin 4;
int loopState = LOOP_STATE_STOPPED;
#define motor 19  // motor attached in relay attached to pin A5
#define vane1 18  // van 1 attached in relay attached to pin A4
#define vane2 17  // van 2 attached in relay attached to pin A3
#define vane3 16  // van 3 attached in relay attached to pin A2
#define vane4 15  // van 4 attached in relay attached to pin A1   // all output (A0,A1,A2,A3,A4,A5) go to ULN2003 to relays
#define fan   14  // fan attached in relay attached to pin A0
//#define bm1    2  // push_button 1 attached betwen pin 2 of arduino and earth
//#define bm2    3  // push_button 2 attached betwen pin 3 of arduino and earth
//#define bm3    4  // push_button 3 attached betwen pin 4 of arduino and earth
#define led1   5  // led 1 attached betwen pin 5 of arduino and earth series with 470 ohm resistor
#define led2   6  // led 2 attached betwen pin 6 of arduino and earth series with 470 ohm resistor
#define led3   7  // led 3 attached betwen pin 7 of arduino and earth series with 470 ohm resistor
                  // the leds is combined in button and i need to use them bliking the time of runing one of my program
#define buzz   8  // buzzer attached betwen pin 5 of arduino and earth (in real i run with bc547 )
int i;            // variable for state of incriment and decriment for switching betwin program to other
int a = 1;            // variable for store value of button 1
int b = 1;            // variable for store value of button 2
int c = 1;            // variable for store value of button 3
volatile byte state = LOW; // variable for store value for bliking led the time of runing loop
void blink() // loop bliking led
             state =! state;
void pression()   // this loop is an program for the first button 1 to do when is pressed for first time
                 digitalWrite(led1 ,blink); // i dont know what is the error her because is not bliking when program run and compiling not let me thath wrong
                 digitalWrite(buzz ,HIGH);
                 digitalWrite(buzz , LOW);
                 digitalWrite(motor,HIGH);
                 digitalWrite(fan  ,HIGH);
                 digitalWrite(vane2,HIGH);
                 delay(12000);
                 digitalWrite(motor,LOW);
                 digitalWrite(fan  ,LOW);
                 digitalWrite(vane2,LOW);
                 delay(30000);
                 digitalWrite(vane1,HIGH);
                 delay(20000);
                 digitalWrite(vane1,LOW);
                 digitalWrite(led1 ,LOW);
                 digitalWrite(buzz  ,LOW);
void vaccum()     // this loop is an program for the first button 2 to do when is pressed for first time
              digitalWrite(led2 ,blink);  // i dont know what is the error her because is not bliking when program run and compiling not let me thath wrong
              digitalWrite(buzz,  LOW);
              digitalWrite(vane3,HIGH);
              delay(35000);
              digitalWrite(vane3,LOW);
              delay(25000);
              delay(15000);
              digitalWrite(vane4,HIGH);
              delay(10000);
              digitalWrite(vane4,LOW);
              delay(10000);
              delay(90000);
              digitalWrite(led2 ,LOW);
void pressionp()  // this loop is an program for the first button 3 to do when is pressed for first time
                 digitalWrite(led3 ,blink);  // i dont know what is the error her because is not bliking when program run and compiling not let me thath wrong
                 delay(12000);
                 digitalWrite(motor ,LOW);
                 digitalWrite(vane2 ,LOW);
                 delay(24000);
                 delay(20000);
                 digitalWrite(vane1 ,LOW);
                 digitalWrite(led3  ,LOW);
   void off()    // this loop is an program for the all button 1,2 and 3 to do when is pressed for second time
               delay(2000);
             button.setDebounceTime(50);  // set debounce time to 50 milliseconds
             button1.setDebounceTime(50); // set debounce time to 50 milliseconds
             button2.setDebounceTime(50); // set debounce time to 50 milliseconds
//             pinMode(bm1  ,INPUT_PULLUP);
//             pinMode(bm2  ,INPUT_PULLUP);
//             pinMode(bm3  ,INPUT_PULLUP);
             pinMode(motor      ,OUTPUT);
             pinMode(vane1      ,OUTPUT);
             pinMode(vane2      ,OUTPUT);
             pinMode(vane3      ,OUTPUT);
             pinMode(vane4      ,OUTPUT);
             pinMode(fan        ,OUTPUT);
             pinMode(led1       ,OUTPUT);
             pinMode(led2       ,OUTPUT);
             pinMode(led3       ,OUTPUT);
             pinMode(buzz       ,OUTPUT);
             button.loop(); // MUST call the loop() function first
             if (button.isPressed())
                                     if (loopState == LOOP_STATE_STOPPED)
                                     loopState = LOOP_STATE_STARTED;
                                     else // if(loopState == LOOP_STATE_STARTED)
                                     off();
                                   if (loopState == LOOP_STATE_STARTED)
        pression();
             if (button1.isPressed())
                                     off();
        vaccum();
             if (button2.isPressed())
                                     off();
        pressionp();
Welcome to the forum
I am sorry to be the bearer of bad news but need to get rid of all of the delay()s in your sketch because whilst each of them is happening nothing else, including reading an input, can be done
Basically you need to write your sketch in a completely different way
See Using millis() for timing. A beginners guide, Several things at the same time and the BlinkWithoutDelay example in the IDE
tank's you for your quick reply
i will see the link and read it
and i will test him
tank you
Blockquote
How can switch betwin two loop usinig one button? - #2 by UKHeliBob
Blockquote
tank's you its solving
