How can this be? a NOT used library must be installed to make the compiler compile?!?!?
From a question that was post here
I'm still using Arduino-IDE 1.8.19 (don't like IDE 2.X)
I encountered a very strange problem.
The compiling aborted with this error-message
Alternatives for Nextion.h: [ITEADLIB_Arduino_Nextion-master]
ResolveLibrary(Nextion.h)
  -> candidates: [ITEADLIB_Arduino_Nextion-master]
Nextion-Demo-Code-001:11:1: error: 'Nextion' does not name a type; did you mean 'nextion'?
 Nextion myNextion(nextion, 9600); //create a Nextion object named myNextion using the nextion serial port @ 9600bps
 nextion
F:\myData\Arduino\Nextion-Demo-Code-001\Nextion-Demo-Code-001.ino: In function 'void setup()':
Nextion-Demo-Code-001:15:3: error: 'myNextion' was not declared in this scope
   myNextion.init();
F:\myData\Arduino\Nextion-Demo-Code-001\Nextion-Demo-Code-001.ino:15:3: note: suggested alternative: 'nextion'
   myNextion.init();
   nextion
F:\myData\Arduino\Nextion-Demo-Code-001\Nextion-Demo-Code-001.ino: In function 'void loop()':
Nextion-Demo-Code-001:20:20: error: 'myNextion' was not declared in this scope
   String message = myNextion.listen(); //check for message
F:\myData\Arduino\Nextion-Demo-Code-001\Nextion-Demo-Code-001.ino:20:20: note: suggested alternative: 'nextion'
                    nextion
Bibliothek ITEADLIB_Arduino_Nextion-master im Ordner: F:\myData\Arduino\libraries\ITEADLIB_Arduino_Nextion-master (legacy) wird verwendet
Bibliothek SPI in Version 1.0 im Ordner: C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI  wird verwendet
Bibliothek SD in Version 1.2.4 im Ordner: F:\myData\Arduino\libraries\SD  wird verwendet
exit status 1
The compiler-log says
ResolveLibrary( Nextion.h )
This is this library
But only after installing this different nextion-library
the compiling was successful.
BUT
the compiler-log of the successful compilation shows the exact same:
Alternatives for Nextion.h: [ITEADLIB_Arduino_Nextion-master nextion]
  -> candidates: [ITEADLIB_Arduino_Nextion-master nextion]
Am I right if I conclude that in the logline that talks about candidates the compiler lists up the not used libraries
and the only line that shows which library is really used is this one:
Compiling library "nextion"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\......
F:\myData\Arduino\libraries\nextion\Nextion.cpp: In member function 'unsigned int Nextion::getComponentValue(String)':
F:\myData\Arduino\libraries\nextion\Nextion.cpp:131:25: warning: left shift count >= width of type [-Wshift-count-overflow]
     value = (temp[4] << 24) | (temp[3] << 16) | (temp[2] << 8) | (temp[1]);//Little-endian convertion
F:\myData\Arduino\libraries\nextion\Nextion.cpp:131:43: warning: left shift count >= width of type [-Wshift-count-overflow]
F:\myData\Arduino\libraries*nextion*\
and due to this inglorious custom of naming the library short and uniform
nextion.h (from author 1)
nextion.h (from author 2)
nextion.h (from author 3)
nextion.h (from author 1001)
you have to look very close to the path to determine which library was really used?
best regards Stefan
Hi @StefanL38
Look again closely. They are not the exact same. The list in the output from the original compilation only contains a single element:
and the output from the later compilation contains two elements:
No, you are not right. That is a list of all libraries that contained a file with the name Nextion.h.
No, there should be a summary at the end of the verbose compilation output that shows which dependencies were used. Something like this:
Multiple libraries were found for "Nextion.h"
 Used: C:\Users\per\Documents\Arduino\libraries\Nextion
 Not used: C:\Users\per\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-master
Using library Nextion at version 2.0.2 in folder: C:\Users\per\Documents\Arduino\libraries\Nextion
Using library SoftwareSerial at version 1.0 in folder: C:\Users\per\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial
I agree that there is a problem of people using generic header filenames that are prone to collisions, but you should note that this is not the library name. The library name is defined by the value of the name field in the library.properties metadata file.
I think the summary at the end of the compilation output makes it fairly clear.
Hi @ptillisch
thank you very much for answering and explaining
After installing the bborncr-nextion-library the compiler-log still lists only one library
complete compiler-log of the aborted compilation
E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware -hardware C:\Users\dipl-\AppData\Local\Arduino15\packages -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\tools-builder -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware\tools\avr -tools C:\Users\dipl-\AppData\Local\Arduino15\packages -built-in-libraries E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\libraries -libraries F:\myData\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_383896 -warnings=default -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_890543 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose F:\myData\Arduino\Nextion-Demo-Code-001\Nextion-Demo-Code-001.ino
E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware -hardware C:\Users\dipl-\AppData\Local\Arduino15\packages -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\tools-builder -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware\tools\avr -tools C:\Users\dipl-\AppData\Local\Arduino15\packages -built-in-libraries E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\libraries -libraries F:\myData\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_383896 -warnings=default -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_890543 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose F:\myData\Arduino\Nextion-Demo-Code-001\Nextion-Demo-Code-001.ino
Using board 'mega' from platform in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o nul
Alternatives for SoftwareSerial.h: [SoftwareSerial@1.0 EspSoftwareSerial@6.15.2 EspSoftwareSerial@8.0.3]
ResolveLibrary(SoftwareSerial.h)
  -> candidates: [SoftwareSerial@1.0 EspSoftwareSerial@6.15.2 EspSoftwareSerial@8.0.3]
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexButton.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexCheckbox.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexCrop.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexDualStateButton.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexGauge.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexGpio.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexHardware.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexHotspot.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexNumber.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexObject.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexPage.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexPicture.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexProgressBar.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexRadio.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexRtc.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexScrolltext.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexSlider.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexText.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexTimer.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexTouch.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexUpload.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexUpload.cpp" -o nul
Alternatives for SD.h: [SD@1.2.4 SD@1.2.4]
ResolveLibrary(SD.h)
  -> candidates: [SD@1.2.4 SD@1.2.4]
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexUpload.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexVariable.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "F:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master\\NexWaveform.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src\\SPI.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "F:\\myData\\Arduino\\libraries\\SD\\src\\File.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "F:\\myData\\Arduino\\libraries\\SD\\src\\SD.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "F:\\myData\\Arduino\\libraries\\SD\\src\\utility\\Sd2Card.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "F:\\myData\\Arduino\\libraries\\SD\\src\\utility\\SdFile.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "F:\\myData\\Arduino\\libraries\\SD\\src\\utility\\SdVolume.cpp" -o nul
Generating function prototypes...
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"E:\\Arduino-funktioniert\\arduino-1.8.19-windows-2022-01-30\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\ITEADLIB_Arduino_Nextion-master" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IF:\\myData\\Arduino\\libraries\\SD\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp.o"
 nextion
   myNextion.init();
   myNextion.init();
   nextion
                    nextion
Mehrere Bibliotheken wurden für "SD.h" gefunden
 Benutzt: F:\myData\Arduino\libraries\SD
 Nicht benutzt: E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\libraries\SD
Mehrere Bibliotheken wurden für "SoftwareSerial.h" gefunden
 Benutzt: C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial
 Nicht benutzt: E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\libraries\EspSoftwareSerial
 Nicht benutzt: F:\myData\Arduino\libraries\EspSoftwareSerial
Bibliothek SoftwareSerial in Version 1.0 im Ordner: C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial  wird verwendet
exit status 1
complete log of the successful compilation
Alternatives for SoftwareSerial.h: [EspSoftwareSerial@6.15.2 EspSoftwareSerial@8.0.3 SoftwareSerial@1.0]
  -> candidates: [EspSoftwareSerial@6.15.2 EspSoftwareSerial@8.0.3 SoftwareSerial@1.0]
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "F:\\myData\\Arduino\\libraries\\nextion\\Nextion.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp.o"
Compiling libraries...
Compiling library "SoftwareSerial"
Zuvor kompilierte Datei wird verwendet: C:\Users\dipl-\AppData\Local\Temp\arduino_build_383896\libraries\SoftwareSerial\SoftwareSerial.cpp.o
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "-IF:\\myData\\Arduino\\libraries\\nextion" "F:\\myData\\Arduino\\libraries\\nextion\\Nextion.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\libraries\\nextion\\Nextion.cpp.o"
Compiling core...
Using precompiled core: C:\Users\dipl-\AppData\Local\Temp\arduino_cache_890543\core\core_arduino_avr_mega_cpu_atmega2560_cbf59aea3d48275ca0a46a930fe90002.a
Linking everything together...
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega2560 -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.elf" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\sketch\\Nextion-Demo-Code-001.ino.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\libraries\\SoftwareSerial\\SoftwareSerial.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896\\libraries\\nextion\\Nextion.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/..\\arduino_cache_890543\\core\\core_arduino_avr_mega_cpu_atmega2560_cbf59aea3d48275ca0a46a930fe90002.a" "-LC:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896" -lm
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.elf" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.eep"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.elf" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.hex"
Mehrere Bibliotheken wurden für "Nextion.h" gefunden
 Benutzt: F:\myData\Arduino\libraries\nextion
 Nicht benutzt: F:\myData\Arduino\libraries\ITEADLIB_Arduino_Nextion-master
Bibliothek nextion im Ordner: F:\myData\Arduino\libraries\nextion (legacy) wird verwendet
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_383896/Nextion-Demo-Code-001.ino.elf"
Der Sketch verwendet 7542 Bytes (2%) des Programmspeicherplatzes. Das Maximum sind 253952 Bytes.
Globale Variablen verwenden 342 Bytes (4%) des dynamischen Speichers, 7850 Bytes für lokale Variablen verbleiben. Das Maximum sind 8192 Bytes.
for easier comparing in one section
START START START START START START START START START START START START START
aborted compilation:
aborted compilation
END END END END END END END END END END END END END END END END
START ## START ## START ## START ## START ## START ## START ## START ## START ## START ##
succesfull compilation
## END ## ## END ## ## END ## ## END ## ## END ## ## END ## ## END ##
of successful compilation
best regards Stefan
So that I can provide an explanation, please provide one of the following:
  • If you installed it via Library Manager, the name of the library as shown in Library Manager (there is no library named "bborncr-nextion-library" there)
  • If you installed it manually, the link to where you downloaded the library from.
bborncr
ITEAD
I'm not able to reproduce it. I did this:
  1. Click the following link to download the library's ZIP file:
    https://github.com/bborncr/nextion/archive/refs/heads/master.zip
  2. Wait for the download to finish.
  3. Select Sketch > Include library > Add .ZIP Library from the Arduino IDE menus.
  4. Select the downloaded file.
  5. Click the Open button.
  6. Wait for the message to appear on the teal bar in the Arduino IDE Window:
    Library added to your libraries. Check "Include library" menu
  7. Click the following link to download the library's ZIP file:
    https://github.com/itead/ITEADLIB_Arduino_Nextion/archive/refs/heads/master.zip
  8. Wait for the download to finish.
  9. Select Sketch > Include library > Add .ZIP Library from the Arduino IDE menus.
  10. Select the downloaded file.
  11. Click the Open button.
  12. Wait for the message to appear on the teal bar in the Arduino IDE Window:
  13. Create the following sketch:
    #include <Nextion.h>
    void setup() {}
    void loop() {}
  14. Select File > Preferences... from the Arduino IDE menus.
    The "Preferences" dialog will open.
  15. Check the box next to "Show verbose output during: ☐ compilation" in the "Preferences" dialog.
  16. Click the OK button.
  17. Select Tools > Board > Arduino AVR Boards > Arduino Mega or Mega 2560 from the Arduino IDE menus.
  18. Select Sketch > Verify/Compile from the Arduino IDE menus.
The compilation output shows that both libraries were identified as candidates for the Nextion.h header:
  -> candidates: [ITEADLIB_Arduino_Nextion-master nextion-master]
 Used: C:\Users\per\Documents\Arduino\libraries\nextion-master
Using library nextion-master in folder: C:\Users\per\Documents\Arduino\libraries\nextion-master (legacy)
If you perform the same procedure, do you get different results?
If my procedure did not effectively replicate the environment on your system, then please provide detailed instructions I can follow to reproduce the results you are reporting.
Hi @ptillisch,
I did The favorite pastime of all modern electronic devices: re-booting
And after the re-boot both libraries appear in the compiler-log
E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware -hardware C:\Users\dipl-\AppData\Local\Arduino15\packages -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\tools-builder -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware\tools\avr -tools C:\Users\dipl-\AppData\Local\Arduino15\packages -built-in-libraries E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\libraries -libraries F:\myData\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_625836 -warnings=default -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_890543 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose F:\myData\Arduino\nextion-test-001\nextion-test-001.ino
E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware -hardware C:\Users\dipl-\AppData\Local\Arduino15\packages -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\tools-builder -tools E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\hardware\tools\avr -tools C:\Users\dipl-\AppData\Local\Arduino15\packages -built-in-libraries E:\Arduino-funktioniert\arduino-1.8.19-windows-2022-01-30\arduino-1.8.19\libraries -libraries F:\myData\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\dipl-\AppData\Local\Temp\arduino_build_625836 -warnings=default -build-cache C:\Users\dipl-\AppData\Local\Temp\arduino_cache_890543 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\dipl-\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose F:\myData\Arduino\nextion-test-001\nextion-test-001.ino
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\sketch\\nextion-test-001.ino.cpp" -o nul
Alternatives for Nextion.h: [nextion ITEADLIB_Arduino_Nextion-master]
  -> candidates: [nextion ITEADLIB_Arduino_Nextion-master]
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IF:\\myData\\Arduino\\libraries\\nextion" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\sketch\\nextion-test-001.ino.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IF:\\myData\\Arduino\\libraries\\nextion" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\sketch\\nextion-test-001.ino.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IF:\\myData\\Arduino\\libraries\\nextion" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "F:\\myData\\Arduino\\libraries\\nextion\\Nextion.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IF:\\myData\\Arduino\\libraries\\nextion" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o nul
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IF:\\myData\\Arduino\\libraries\\nextion" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\sketch\\nextion-test-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"E:\\Arduino-funktioniert\\arduino-1.8.19-windows-2022-01-30\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IF:\\myData\\Arduino\\libraries\\nextion" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\sketch\\nextion-test-001.ino.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\sketch\\nextion-test-001.ino.cpp.o"
Compiling library "nextion"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IF:\\myData\\Arduino\\libraries\\nextion" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "F:\\myData\\Arduino\\libraries\\nextion\\Nextion.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\libraries\\nextion\\Nextion.cpp.o"
F:\myData\Arduino\libraries\nextion\Nextion.cpp: In member function 'unsigned int Nextion::getComponentValue(String)':
F:\myData\Arduino\libraries\nextion\Nextion.cpp:131:25: warning: left shift count >= width of type [-Wshift-count-overflow]
     value = (temp[4] << 24) | (temp[3] << 16) | (temp[2] << 8) | (temp[1]);//Little-endian convertion
F:\myData\Arduino\libraries\nextion\Nextion.cpp:131:43: warning: left shift count >= width of type [-Wshift-count-overflow]
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IF:\\myData\\Arduino\\libraries\\nextion" "-IC:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src" "C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\libraries\\SoftwareSerial\\SoftwareSerial.cpp.o"
Compiling core...
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega2560 -o "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836/nextion-test-001.ino.elf" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\sketch\\nextion-test-001.ino.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\libraries\\nextion\\Nextion.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836\\libraries\\SoftwareSerial\\SoftwareSerial.cpp.o" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836/..\\arduino_cache_890543\\core\\core_arduino_avr_mega_cpu_atmega2560_cbf59aea3d48275ca0a46a930fe90002.a" "-LC:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836" -lm
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836/nextion-test-001.ino.elf" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836/nextion-test-001.ino.eep"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836/nextion-test-001.ino.elf" "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836/nextion-test-001.ino.hex"
"C:\\Users\\dipl-\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\dipl-\\AppData\\Local\\Temp\\arduino_build_625836/nextion-test-001.ino.elf"
Der Sketch verwendet 1698 Bytes (0%) des Programmspeicherplatzes. Das Maximum sind 253952 Bytes.
Globale Variablen verwenden 186 Bytes (2%) des dynamischen Speichers, 8006 Bytes für lokale Variablen verbleiben. Das Maximum sind 8192 Bytes.
I don't have an explanation for why a reboot would be needed. It is true that older versions of Arduino IDE 1.x (I believe <1.6.5) did only recognize externally (manually adding the library to the libraries folder) installed libraries after restarting the IDE. But the recent versions (including 1.8.19, which I used to perform the instructions in my previous reply) search the libraries from disk, so no longer require a restart after external changes to the libraries.
I guess we can be happy that everyone is getting the expected results now at least.
