Dear All, I am happy, my project goes ahed :).
Thank for reading my post. it's a bit long, because I tried to be the more understanding.
I need to listnen my port in case of my SIMD card is removed of if the network is lost.
I found the function listnen() and isListening().
Could let me know if I ma wrong or on a good way. I am a bit septic. For this I will explain how my code work
First, I have a setup. Second I have a loop(). My loop() is like this:
//That value a set back to false in other to have a check of the network
// Check network
establishNetwork();
// THis for debug
//Serial.println("Loop() Delay of 2 sec");
//delay(SEND_DELAY);
I call the function etablishNetwork()
static void establishNetwork() {
while (GPRS_registered == false || GPRS_AT_ready == false) { // (+SIND 11 || +SIND 4)
Serial.println("");
Serial.println("EtablishNetwork (Pause 2sec)");
delay(2000);
readATString();
ProcessATString();
// This is for debug
Serial.print("********************************************");
When +SIND: 11 and +SIND:4 are received GRPS_registered and GPRS_AT_ready are turn to true, then the loop stop That function call two other.
First, etablishNetwork() loops readATString() once and return +SIND:1, as GRPS_registered and GPRS_AT_ready are stile false, etablishNetwork() loop it again and return +SIND:3, and it continue looping until it get +SIND:11, and turn GPRS_registered true, again it continue until it get +SIND:4 and turn GRPS_AT_ready to true. Those values are turn to true in ProcessATString(). I will show the code later.
static void readATString() {
char buffidx = 0;
int time = millis();
//while (strstr(at_buffer, "+SIND: 4") == 0 && strstr(at_buffer, "+SIND: 10,\"SM\",1,\"FD\",1,\"LD\",1,\"MC\",1,\"RC\",1,\"ME\",1") == 0) {
while (1) {
Serial.println("=> Loop start"); // For debug
if (cell.available() > 0) {
incoming_char = cell.read();
if (incoming_char == -1) {
at_buffer[buffidx] = '\0';
Serial.print("--------------------------1"); // For debug
return;
if (incoming_char == '\n') {
Serial.println("continue"); // For debug
continue;
if ((buffidx == BUFFSIZE - 1) || incoming_char == '\r') {
Serial.println("return R"); // For debug
return;
at_buffer[buffidx++] = incoming_char;
}else{
Serial.println("cell not available (RETURN)");
//return;
Serial.println("=> Loop end"); // For debug
Serial.println(""); // For debug
When at_buffer get +SIND: 1 , ProcessATString() come in action and display the message for. Same, when at_buffer get +SIND:4, ProcessATStrine come in action, display a message and turne GPRS_ready to true.
It seams to work well. From that point, the loop() is looping...
// Check network
establishNetwork();
// THis for debug
... and at each time, etablishNetwrok() is calling, but nothing happen because GPRS_at_ready and GPRS_regostered are true. Then if I remove the SIM card or, I do not know, if I lost the network, or something else, the function readATString() will never be called, because GPRS_at_ready and GPRS_registered are true.
My question, now :). I would like to listened this SoftwareSerial cell(GPRS_TX, GPRS_RX); //int GPRS_TX = 2; int GPRS_RX = 3; or the ports, in case of incoming_char = cell.read(); return +SIND: 0, or +SIND: 7, or something else.
As I wrote, I found .listnen() and .isListing(). I saw that exemple
portOne.listen();
if (portOne.isListening()) {
Serial.println("Port One is listening!");
}else{
Serial.println("Port One is not listening!");
if (portTwo.isListening()) {
Serial.println("Port Two is listening!");
}else{
Serial.println("Port Two is not listening!");
but I am a bit confused. In my case, I suppose, I should adapt it like this
cell.listen();
if (cell.isListening()) {
}else{
But now, if I am in the right way, how should I red cell, in order to cacht the code +SIND:0, +SIND:7 etc ???? The code should be catch from listnen() or from isListning()??
Thank for ready my long post. I hope I was clear and thank for your help and advise.
Cheers
