Hello guys, I'm facing a problem in figuring out how to make my program accept only integer input and prompt the user to re enter a valid integer if not?
I wrote the following program for checking if the integer entered is a prime number or not. I need help about how can I make this program accept only integer input and prompt the user if an invalid input like a character or float number is entered.
int num1;
int num2;
int num3;
int i=2;
int checkerflag=0;
int printcounter=0;
void setup(){
Serial.begin(9600); //begins serial communication
if(printcounter==0)
Serial.println("Enter the integer to check if prime or not");
printcounter=1;
while(Serial.available()>0)
num1=Serial.parseInt();
num2=sqrt(num1)+2;
checker();
void checker()
while(i<num2)
num3=num1%i;
if(num3==0){checkerflag=1; break;}
i=i+1;
Serial.print("Number ");
Serial.print(num1);
if(checkerflag==0)
Serial.println(" is a prime.");
Serial.println(" is not a prime");
checkerflag=0;
i=2;
Thank you in advance
