How change number for variable
I'm doing with own code, variable number try change for "if" but same stay "hold==0" how let change number like from "hold==0;" to "hold==2;"
int hold; . . . if (hold==0) { void xxxxxx(); . hold==2; //try change to 2 from 0 }
how what code let change to 2 from 0? "hold==2;" no error but didnt changed is 2 after 0 when "if (hold==0)" still often passing.
Can you try again, those words make no sense.
double == is a comparison single = is an assignment
Well done robtillaart for spotting what he was confused about.
Just to make the point To change the value of a variable use:- hold = 0 to test the value of a variable use:- if( hold == 0 )
Always use == inside an if statement never outside it.
robtillaart, realized, single = is an assignment that change the value of variable, perfect works. Grumpy_Mike, I got it, thanks.
Grumpy_Mike: Always use == inside an if statement never outside it.
Not completely true, sometimes there is no if statement (visible)
bool engineStarted = (digitalRead(enginePin) == HIGH);
or
if (Serial.available())
  c = Serial.Read();
  digitalWrite(somePin, c == 'h');
These code constructs can always be rewritten to an if statement
  c = Serial.Read();
  if (c=='h') digitalWrite(somePin, HIGH);
  else digitalWrite(somePin, LOW);
There are strange constructions possible with == like
bool x = ((a==b) == (c==d)); // to be extended infinitely
