I have a camera with usb output(FTDI chip) and my camera speed is 1000 FPS. i connect properly with this chip through c# application, i use FTD2XX.DLL available in "Code Examples - FTDI" for this work.
now, i want to connect this chip to my arduino board for read data and i want to use below library for this work Arduino/build/windows/dist/drivers/FTDI USB Drivers at master · arduino/Arduino · GitHub
i have below question:
1-do i can use this library? if yes,how can add this library?
2-do can arduino support this speed(because The CPU is only clocked at 16MHz which is much slower than some USB data rates)
3-do have anyone advice or Experience on use of FPGA or ARM for this?
mmhr:
2 megabytes of data is involved in 1000 FPS . in your opinion, which platform Is appropriate?
Do you mean 2 megabytes per frame ? 640x480x3 (3 for full colour) is 0.9MB Most cameras now are much higher resolution than that. The JPEG still images on my camera are about 3MB each.
Robin2:
Do you mean 2 megabytes per frame ? 640x480x3 (3 for full color) is 0.9MB Most cameras now are much higher resolution than that. The JPEG still images on my camera are about 3MB each.
At least a Raspberry Pi.
...R
this camera is line scan no area scan and have only 2048 pixel(black and white), yes 2 megabytes per frame.
i am not familiar with Raspberry Pi, in your opinion below tutorial is appropriate for me?
mmhr:
This makes no sense. How do you get from 2048 pixels to 2 megabtyes.
If your camera already has USB output and an RPi has USB input why would need any FTDI device ? An RPi is just a small PC without a screen or keyboard.
Robin2:
This makes no sense. How do you get from 2048 pixels to 2 megabytes.
because is 2 megabytes each image of this camera!
Robin2:
because is FDTI chip USB output of camera, i can connect to it and read data with C# Application , but can not send output of pc to other device (for example Arduino board) in high speed(less than 3ms) , speed is 200 ms of pc to arduino Through Ethernet port(for 40 output).
so, I decided to connect directly my camera to other device and active or deactivate output pin Without interface.
mmhr:
Then it is NOT 2048 pixels - 2048 is 2 thousand, not 2 million
I know you cannot connect it to an Arduino - but we have told you it is not suitable.
If you can connect it to a PC you should be able to connect it to a Raspbery Pi - you just can't program a Pi with C# which is a Windows product.
This is no longer an Arduino Forum problem. Perhaps there is an RPI Forum ?
