How control microcontroller by esp-07 and android
I want create project with controlling device by smartphone, i have esp-07 for this. I'm searched the internet for look how do it, but not find good idea for implement this. With esp-12 the same case?
Struckman:
Correct. The ESP-07 and ESP-12 just two different models of ESP8266 modules. I believe the only difference between the two is that the ESP-07 has a ceramic antenna and a U.FL antenna connector, while the ESP-12 has a PCB antenna. That difference has no relevance when it comes to writing code for the modules. So when you're doing research, don't poison your searches by using the "ESP-07" keyword. Instead, use the "ESP8266" keyword and you'll get far more search results.
Struckman:
A little searching will turn up sites and projects like below.
https://randomnerdtutorials.com/?s=web+server
