Hi all,
I have an ESP8266 Nodemcu, with an 1,8" TFT.
I want to control the bright of the screen with one pin. I test with a transistor and work soso because the Vcc to the TFT is 3.3V, and with the transistor I lost 0,7 from Vbe, so the bright on the TFT never reach maximum. Now I have connected to a 2N2222, wired:
tft gnd to Collector
Control pin to Base, with a RLim.
Emisor to general GND
But this is like a switch.
Is there a way to control the TFT in order to modify bright?
Pepeillo:
...and with the transistor I lost 0,7 from Vbe, so the bright on the TFT never reach maximum.
That doesn't make sense.
Collector-emitter voltage of a bjt transistor used as a switch can get much lower than base-emitter voltage.
Typical ~0,2volt. A mosfet could do better than that.
Make sure you have enough base current to fully saturate the transistor (typ. 10% of the collector current).
