How convert CCButton in a Toggle Switch?
Hi everyone, in first place thanks to Pieterp for his help and work:
I use the Control_Surface library (great work), and i tried many times modify the code but i cant resolve it, the question its simple; How convert CCButton in Toggle Switch?
i use a Push Button in pin 11.
Thanks.
Modify what code?
Solutioned, the problem: To modify code without update the library (i iused 2019 version).
thanks
You can use Control Surface: CCButtonLatched Class Reference.
Thanks Pieter, CCButtonLatched Class worked i when updated library.
Another question, How a rotary encoder cans incrementing 1 value at time? (1,2,3 ... 127) and not 0-127?
Rotary encoder with the library works fine with reaper´s mapping, but externals vst not, the values ​​(knobs) goes bottom at top.
thanks
If these VSTs don't support relative messages, you'll have to use the CCAbsoluteEncoder class.
You can find a full overview of MIDI output elements on Control Surface: MIDI Output Elements.
