how copy contents of a text file to variable? Help me please!!
My friends who can help thanks.
Must pass the contents of a text file that is in the Arduino sd to a variable .
For example:
the text file has the following names :
Will be just these four names, neither more nor less .
Jack
David
Rose
Steve
then I would have 4 variables :.
variable a = Jack
variable b = David
variable c = Rose
variable d = Steve
How to ?
Help me please!!
Have you looked at any of the SD examples?
I not found an example for this :confused:
Really?
in the example above , failed to send text to a variable...
I need the text in the variable for handle
Jack
David
Rose
Steve
If that's all the file contains, why bother?
Just copy the strings to string variables. Job done.
You could make a small example ?
You will need the SdFat library in this link.
Here are two example:
readFile()
readDirectory()
See the comments to see where you get the Directory Entry Name and the File Line as string.
#include <SPI.h>
#include <SdFat.h>
#define DIRECTORY_ENTRY_LENGTH  30
#define FILE_LINE_LENGTH        30
SdFat SD;             //Main SD Object
  if(!SD.begin(SS)){  //Initialize the SD card using SPI pins + ChipSelect pin
    Serial.println(" Error initializing SD Card ");
    return;
  readDirectory("/");       //Read root directory
  readFile("/","Test.txt"); //Read file in Root directory
  /* NOTHING */
void readDirectory(char* Path){
  Serial.print(F(" -- Reading entries from path = "));
  Serial.println(Path);
  SdFile directory;   //SD Object
  char EntryName[DIRECTORY_ENTRY_LENGTH];
  memset(EntryName,0,sizeof(EntryName));
  if(SD.chdir(Path)){
    while(directory.openNext(SD.vwd(), O_READ)){
      directory.getName(EntryName,sizeof(EntryName)-1);
      if(directory.isDir())
        strcat(EntryName,"/");
      Serial.print(F(" * "));
      Serial.println(EntryName); //This is where you get one entry name at a time.
      directory.close();
    Serial.println(F("ERROR: Couldn't open path."));
  Serial.println(F("DONE Reading"));
void readFile(char* Path, char* FileName){
  Serial.print(F(" -- Reading entries from file = "));
  Serial.print(Path);
  Serial.println(FileName);
  SdFile directory;
  SdFile file;
  if(SD.chdir(Path)){
    if(file.open(FileName)){
      char Line[FILE_LINE_LENGTH];
      memset(Line,0,sizeof(Line));
      char Char[2];
      memset(Char,0,sizeof(Char));
      while (file.available()) {
        Char[0] = file.read();
        if(Char[0]=='\n'){
          Serial.println(Line); //This is where you get one line of file at a time.
        else if(Char[0]>=32)
          strcat(Line,Char);
      file.close();
      Serial.println(F("ERROR: Couldn't open file."));
    directory.close();
Thank you all
