i am using esp32 and the library RC-Switch
The sensor is this:
I have tested the receiver and transmitter with sample code used is SendDemo and ReceiveDemo_Advanced, and is working.
but wen i test with home remote controller is not working,
The frequency of my remote control is 433.88Mhz (NATERIAL DC1600)
So I would like to ask what kind of library and sensor I should use to receive the 433.88MHz data?
There are several variations of the RC-switch signal protocol and only one can be recognized at a time. The controller may not use the RC-switch protocol, or it may use a variation that is not recognized by the RC-switch library.
You can check here, or search on line to see if your controller is supported.
