How Could I Achieve 3000Hz Sampling Rate on Arduino Uno+ADXL345 ?
Hello arduino community,
I have used Arduino Uno +ADXL345 to get the acceleration data on serial monitor.
I would like to reach 3000Hz sampling rate in my work,however I could only reach 700Hz sampling rate.
Could anyone help me to solve my problem?
I will appreciate your help with this situation.
Here is my code: (I use I^2C to connect)
#include <Wire.h>
#include<TimerOne.h>
#define Register_ID 0
#define Register_2D 0x2D
#define Register_X0 0x32
#define Register_X1 0x33
#define Register_Y0 0x34
#define Register_Y1 0x35
#define Register_Z0 0x36
#define Register_Z1 0x37
int ADXAddress = 0xA7>>1;
int reading = 0;
int val = 0;
int X0,X1,X_out;
int Y0,Y1,Y_out;
int Z1,Z0,Z_out;
double Xg,Yg,Zg;
void stoptrans()
Serial.println(Xg);
Serial.println(Yg);
Serial.println(Zg);
Wire.begin(); // initial I2C
Serial.begin(921600);
Wire.beginTransmission(ADXAddress);
Wire.write(Register_2D);
Wire.write(8 ); //measuring enable
Wire.endTransmission(); //stop transmitting
Timer1.initialize(1400);
Timer1.attachInterrupt(stoptrans,1400);
Wire.beginTransmission(ADXAddress); // transmit to device
Wire.write(Register_X0);
Wire.write(Register_X1);
Wire.requestFrom(ADXAddress,2);
if(Wire.available()<=2);
X0 = Wire.read();
X1 = Wire.read();
X1 = X1<<8;
X_out = X0+X1;
Wire.write(Register_Y0);
Wire.write(Register_Y1);
Y0 = Wire.read();
Y1 = Wire.read();
Y1 = Y1<<8;
Y_out = Y0+Y1;
Wire.write(Register_Z0);
Wire.write(Register_Z1);
Z0 = Wire.read();
Z1 = Wire.read();
Z1 = Z1<<8;
Z_out = Z0+Z1;
Xg = X_out/256.00; //?????????????g,???????2??
Yg = Y_out/256.00;
Zg = Z_out/256.00;
Posting (badly) the same code twice is not likely to gain you any friends.
Do not cross-post, it wastes time.
Use tags when posting code.
I think default I2C speed is 100 KHz.
Figure out how to get it to 400 KHz, that will help a lot there.
You have what looks like 7 transfers with every access, that slows the rate down some too.
Some processing time for the if statements and the byte to int math, it all adds up.
I bet this32-bit math takes some time too:
Xg = X_out/256.00;
Yg = Y_out/256.00;
Zg = Z_out/256.00;
