i have arduino uno and 2 servo motor ,one of them attached to ultra sonic sensor and rotate from 0-180 and return"radar" i used "processing apps" to interface targets
how could i make second servo to point to the target (second servo connected to rocket model) by angle
i uploaded 2 codes that i used
#include <Servo.h>
const int trigPin=9;
const int echoPin=10;
long duration;
int distance;
Servo s1;
pinMode(trigPin,OUTPUT);
pinMode(echoPin,INPUT);
s1.attach(11);
for(int i=15;i<=165;i++){ // rotates the servo motor from 15 to 165 degrees
s1.write(i);
delay(30);
distance = calDist();
Serial.print(i); // Sends the current degree into the Serial Port
Serial.print(","); // Sends addition character right next to the previous value needed later in the Processing IDE for indexing
Serial.print(distance); // Sends the distance value into the Serial Port
Serial.print("."); // Sends addition character right next to the previous value needed later in the Processing IDE for indexing
for(int i=165;i>15;i--){
s1.write(i);
delay(30);
Serial.print(i);
Serial.print(",");
Serial.print(".");
int calDist()
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2; // Range : 2cm to 400 cm
return distance;
import processing.serial.*; // imports library for serial communication
Serial myPort; // defines Object for Serial
String ang="";
String distance="";
String data="";
int angle, dist;
size (1200, 700);
myPort = new Serial(this,"COM4", 9600); // starts the serial communication
myPort.bufferUntil('.'); // reads the data from the serial port up to the character '.' before calling serialEvent
background(0);
void draw() {
//for the blur effect
fill(0,5); //colour,opacity
noStroke();
rect(0, 0, width, height*0.93);
noStroke();
fill(0,255);
rect(0,height*0.93,width,height); // so that the text having angle and distance doesnt blur out
drawRadar();
drawLine();
drawObject();
drawText();
void serialEvent (Serial myPort) { // starts reading data from the Serial Port
// reads the data from the Serial Port up to the character '.' and puts it into the String variable "data".
data = myPort.readStringUntil('.');
data = data.substring(0,data.length()-1);
int index1 = data.indexOf(",");
ang= data.substring(0, index1);
distance= data.substring(index1+1, data.length());
angle = int(ang);
dist = int(distance);
System.out.println(angle);
void drawRadar()
pushMatrix();
noFill();
stroke(10,255,10); //green
strokeWeight(3);
translate(width/2,height-height*0.06);
line(-width/2,0,width/2,0);
arc(0,0,(width*0.5),(width*0.5),PI,TWO_PI);
arc(0,0,(width*0.25),(width*0.25),PI,TWO_PI);
arc(0,0,(width*0.75),(width*0.75),PI,TWO_PI);
arc(0,0,(width*0.95),(width*0.95),PI,TWO_PI);
line(0,0,(-width/2)*cos(radians(30)),(-width/2)*sin(radians(30)));
line(0,0,(-width/2)*cos(radians(60)),(-width/2)*sin(radians(60)));
line(0,0,(-width/2)*cos(radians(90)),(-width/2)*sin(radians(90)));
line(0,0,(-width/2)*cos(radians(120)),(-width/2)*sin(radians(120)));
line(0,0,(-width/2)*cos(radians(150)),(-width/2)*sin(radians(150)));
stroke(175,255,175);
strokeWeight(1);
line(0,0,(-width/2)*cos(radians(15)),(-width/2)*sin(radians(15)));
line(0,0,(-width/2)*cos(radians(45)),(-width/2)*sin(radians(45)));
line(0,0,(-width/2)*cos(radians(75)),(-width/2)*sin(radians(75)));
line(0,0,(-width/2)*cos(radians(105)),(-width/2)*sin(radians(105)));
line(0,0,(-width/2)*cos(radians(135)),(-width/2)*sin(radians(135)));
line(0,0,(-width/2)*cos(radians(165)),(-width/2)*sin(radians(165)));
popMatrix();
void drawLine() {
pushMatrix();
strokeWeight(9);
stroke(0,255,0);
line(0,0,(width/2)*cos(radians(angle)),(-width/2)*sin(radians(angle)));
popMatrix();
void drawObject() {
pushMatrix();
strokeWeight(9);
stroke(255,0,0);
float pixleDist = (dist/400.0)*(width/2.0); // covers the distance from the sensor from cm to pixels
float pd=(width/2)-pixleDist;
float x=-pixleDist*cos(radians(angle));
float y=-pixleDist*sin(radians(angle));
if(dist<=40) // limiting the range to 40 cms
//line(0,0,pixleDist,0);
line(-x,y,-x+(pd*cos(radians(angle))),y-(pd*sin(radians(angle))));
popMatrix();
void drawText()
pushMatrix();
fill(100,200,255);
textSize(25);
text("10cm",(width/2)+(width*0.115),height*0.93);
text("20cm",(width/2)+(width*0.24),height*0.93);
text("30cm",(width/2)+(width*0.365),height*0.93);
text("40cm",(width/2)+(width*0.45),height*0.93);
textSize(40);
text("YAinnoware",width*0.08,height*0.99);
text("Angle :"+angle,width*0.45,height*0.99);
if(dist<=40) {
text("Distance :"+dist,width*0.7,height*0.99);
textSize(25);
text(" 30°",(width/2)*cos(radians(30)),(-width/2)*sin(radians(30)));
text(" 60°",(width/2)*cos(radians(60)),(-width/2)*sin(radians(60)));
text("90°",(width/2)*cos(radians(91)),(-width/2)*sin(radians(90)));
text("120°",(width/2)*cos(radians(123)),(-width/2)*sin(radians(118)));
text("150°",(width/2)*cos(radians(160)),(-width/2)*sin(radians(150)));
popMatrix();
ACF.txt (1.73 KB)
PCF.txt (4.91 KB)
