I want making a library in arduino, I have not some idea, I Need help.
I do not know where to start and read what is on the official arduino page but I do not understand anything I need a more clear help please
open up some libray files and have a look at them. they are just a header (.h) file and a source file (.cpp).
the header declares functions variables, and the source file defines the functions.
a library is a collection of variables and functions
OldSteve:
Writing a Library for Arduino
I saw that myself and I did not understand
It's fairly straightforward. Which part didn't you understand?
Did you work through the example and create the 'Morse' library?
Then you are not ready to be creating libraries. When the light comes on, you'll know it, and then you can create a library of your own.
I can't agree more with PaulS Keep learning about writing C/C++ and you'll get there.
Then there are other resources like Adafruit which has a progressive tutorial that begins with some basics here and then introduces classes here.
Learning how to create a class is fundamental to your goal of making a library. Once you have your class working, putting it into the proper file structure is somewhat trivial.
More people should look at those tutorials...
But on the other hand, a class != library on it's own. Nor is a library a class per se. A library can also be plain C if you want to.
septillion:
yes, so in that case OP can run straight to the more trivial bits.
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
Unfortunately, most people want free work and will jump on any opportunity to get such.
Arduino_n00b, why are you digging up a 2.5 year old thread to say something that doesn't even help solve the problem?
