How delays do 2 things and millis do it different. Run the examples and see
Load and run each sketch, use Serial Monitor. Both stop before long.
Be sure to set your Serial Monitor baud rate (speed) to 115200.
  DelayBlink for expierienced users of delay().
  Turns on an LED on for one second, then off for one second, repeatedly.
  Added to tha, blink another led for a short time repeatedly and
  gemerate a time-stamped log of LED actions, hit Enter to stop/start.
  With the log there is no real need to wire in the extra LED.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
byte led = 13;
byte led2 = 7;
byte loops = 0;
byte limitLoopsTo = 5; // stop scrolling forever
// the setup routine runs once when you press reset:
  Serial.begin( 115200 );  // Serial Monitor must match.
  Serial.println( F( "\n\n**** DelayBlink demo. ****" )); // '\n' is newline char
  Serial.println( F( "Log times are milliseconds since start." ));
  Serial.println( F( "~~~~~~~~~~~~~~~~~~~~~~~~~~~~~\n" ));
  // initialize the digital pins as outputs.
  pinMode(led, OUTPUT);
  pinMode(led2, OUTPUT); // if phase 2 is used
// the loop routine runs over and over again forever:
  loops++; // loop count
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  Serial.print( millis());
  Serial.println( F( " LED 13 ON" ));
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
  Serial.println( F( " LED 13 OFF" ));
//  you have 2 leds on different pins
  digitalWrite(led2, HIGH);   // turn the LED on (HIGH is the voltage level)
  Serial.println( F( " LED 7 ON" ));
  delay(200);               // wait for 0.2 second
  digitalWrite(led2, LOW);    // turn the LED off by making the voltage LOW
  Serial.println( F( " LED 7 OFF" ));
//  what happens?
  if ( loops == limitLoopsTo )
    while( 1 ); // always true, locked loop can be reset
  Modified Arduino Blink Converted to NoDelayBlink
  Blinks two leds at different rates at the same time.
  This is for after you have practice with delay code.
  You may have to see it run to know what the deal is,
  but just in case,
  it means merged sketched can run independently
  if one thing runs with delays alone it can be made to run with others.
  And if no task hogs cycles an Uno can do > 100 tasks without stuttering.
// stop the log at millis to linit length
const unsigned long demoLength = 12000;
// give it a name:
byte statusLedPin = 13; // save a byte, Uno has 2048B RAM!
byte statusLedState = 1; // turns ON in setup
byte addedLedPin = 7; // phase 3
byte addedLedState = 1; // turns ON in setup
unsigned long statusLedStart; // gets set at start
unsigned long addedLedStart; // millis!
unsigned long statusLedInterval = 1000; // millis!
unsigned long addedLedInterval = 200; // millis!
void BlinkStatusLight() // shows normal operation
  if ( millis() - statusLedStart >= statusLedInterval )
    statusLedState = !statusLedState; // flips 0/1
    digitalWrite(statusLedPin, statusLedState); // turn the LED on (HIGH is the voltage level)
    statusLedStart += statusLedInterval; // self-correcting
    Serial.print( F( " LED " ));
    Serial.print( statusLedPin );
    Serial.write( ' ' );
    if ( statusLedState == 0 )
      Serial.println( F( "OFF" ));
      Serial.println( F( "ON" ));
} // end of BlinkStatusLight(), it toggles a pin on time
// blinking the added led is really the same as above.
// pnly 1 task can do both BUT
// blinking a led is a filler for Output in general
// this demo is to show independent tasks running.
void BlinkAddedLed() // shows normal operation
  if ( millis() - addedLedStart >= addedLedInterval )
    addedLedState = !addedLedState; // flips 0/1
    digitalWrite(addedLedPin, addedLedState); // turn the LED on (HIGH is the voltage level)
    addedLedStart += addedLedInterval; // self-correcting
    Serial.print( addedLedPin );
    if ( addedLedState == 0 )
} // end of BlinkAddedStatusStatusLight(), it toggles a pin on time
// One more task that measures the void loop average.
// First time was a shock, loop averaged 20 micros.
// It made 67 time checks per timer before 1 ms.
// LoopCounter  --  lets you know how often void loop() ran last second.
// LoopCounter value
#define microsInOneSecond 1000000UL
void LoopCounter() // tells the void loop runs every second
{ // if you add code, this will show you the load
  // it is a load, converting longs to decimal text
  // takes a lot of cycles but only once/second.
  // When you are finished with developing,
  // comment out the void loop call to the counter
  // and your finished code will have less ;atency.
  // inside a function, static variables keep their value from run to run
  static unsigned long count, countStartMicros; // only this function sees these
  count++; // adds 1 to count after any use in an expression, here it just adds 1.
  if ( micros() - countStartMicros >= microsInOneSecond ) // 1 second
    countStartMicros += microsInOneSecond; // for a regular second
    Serial.print( F( "\nLC " ));
    Serial.println( count ); // 32-bit binary into decimal text = many micros
    count = 0; // don't forget to reset the counter
} // end of LoopCounter(), it shows void loop runs every second.
//  ============= VOID SETUP ==============
{ // easier for old eyes to match aligned braces
  Serial.begin( 115200 ); // empty the buffer faster!
  // set your Serial Monitor baud rate to match!
  Serial.println( F( "\n\n**** NoDelayBlink demo. ****" ));
  Serial.println( F( "Log times are milliseconds since startup." ));
  Serial.println( F( "Demo limited to 12 seconds originally." ));
  // initialize the digital pin as an output.
  pinMode(statusLedPin, OUTPUT);
  pinMode(addedLedPin, OUTPUT);
  // leds ON, waiting to turn OFF unless I want else.
  digitalWrite(statusLedPin, HIGH); // turn the LED on (HIGH is the voltage level)
  digitalWrite(addedLedPin, HIGH); // turn the LED on (HIGH is the voltage level)
} // the vertically alighned closing brace
//  ============= VOID LOOP ==============
void loop()  // the driving wheel
  // these tasks will appear to run in parallel
  LoopCounter();
  BlinkStatusLight();
  BlinkAddedLed();
  // every time loop runs they all check the time
  if ( millis() >= demoLength )
    while( 1 ); // no escape
LOL. Here I am looking to find the flaw that causes both sketches to fail after some period of time.
But no, just a planned halt to the endless running the sketches woukd otherwise treat us to… THX.
a7
Scrolling data, it was limit the run or explain a stop-go as well.
Besides, the point is best made before attention is lost.
