I have a 3.5" tft touch screen shield with a micro sd card like this one.
I am trying to get bmp's to appear on it, I can draw lines, squares and circles.
It uses the adafruit_gfx library which shows
drawBitmap(int16_t x, int16_t y, const uint8_t *bitmap,
int16_t w, int16_t h, uint16_t color),
but every way I try to get it to implement this it fails.
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <TouchScreen.h>
#define MINPRESSURE 200
#define MAXPRESSURE 1000
//CONTROLLER ili9481 ili9468, ili9488 hx8357, or r61581
//ID = 0x6814
// ALL Touch panels and wiring are DIFFERENT
// copy-paste results from TouchScreen_Calibr_native.ino
const int XP = 6, XM = A2, YP = A1, YM = 7; //ID=0x9341 (input pins)
//const int TS_LEFT = 912, TS_RT = 189, TS_TOP = 912, TS_BOT = 176;//portrait
//const int TS_LEFT = 912, TS_RT = 176, TS_TOP = 189, TS_BOT = 821;//landscape
const int TS_LEFT = 950, TS_RT = 206, TS_TOP = 189, TS_BOT = 921;//landscape
//this last calculation means touch is directly over drawn boxes.
//is this needed to correct different types of display? screen for my display is 480 x 320
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Adafruit_GFX_Button on_btn, off_btn, top_left_btn, top_rt_btn, bot_left_btn, bot_rt_btn;
int pixel_x, pixel_y;
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
void setup(void)
uint16_t ID = tft.readID();
Serial.print("TFT ID = 0x");
Serial.println(ID, HEX);
Serial.println("Calibrate for your Touch Panel");
//if (ID == 0xD3D3) ID = 0x9486; // write-only shield
tft.begin(ID);
tft.setRotation(1); //0=portrait,1=landscape
tft.fillScreen(BLACK);
//on_btn.initButton(&tft, 60 ,200 , 100 , 40 , WHITE, CYAN,BLACK, "ON", 2 );
// ( ? , in , down,width,height,border,bkgrnd,text, text,size)
// colour,colour,colour,
//319 is bottom row, 0 is left edge. Buttons(in and down above) number from centre of box
//put a spot in each corner
top_left_btn.initButton(&tft, 0 , 0 , 1 , 1 , WHITE, CYAN,BLACK, "", 2 );
bot_left_btn.initButton(&tft, 0 , 319 , 1 , 1 , WHITE, CYAN,BLACK, "", 2 );
top_rt_btn.initButton(&tft, 479 , 0 , 1 , 1 , WHITE, CYAN,BLACK, "", 2 );
bot_rt_btn.initButton(&tft, 479 , 319 , 1 , 1 , WHITE, CYAN, BLACK,"", 2 );
off_btn.initButton(&tft,180 ,200 ,100 , 40 , WHITE, CYAN , BLACK, "OFF", 2 );
on_btn.drawButton(false);
top_left_btn.drawButton(false);
bot_left_btn.drawButton(false);
top_rt_btn.drawButton(false);
bot_rt_btn.drawButton(false);
off_btn.drawButton(false);
// on_btn
tft.fillRect(40, 80, 160, 80, RED);
tft.drawCircle(240,240,60, RED);
tft.drawCircle(360,240,40, BLUE);
tft.fillCircle (360,120,40,RED);
tft.drawBitmap(360,120,*woof.bmp,25,25,RED);
tft.fillRect(240, 0, 1, 1, RED);//puts a red spot middle of top row.
tft.fillRect(240, 0, 1, 319, RED);//put a red line down the middle.
/* two buttons are quite simple
void loop(void)
bool down = Touch_getXY();
on_btn.press(down && on_btn.contains(pixel_x, pixel_y));
off_btn.press(down && off_btn.contains(pixel_x, pixel_y));
if (on_btn.justReleased())
on_btn.drawButton();//renews button background colour
if (on_btn.justPressed()) {
on_btn.drawButton(true);//deletes button background colour
tft.fillRect(40, 80, 160, 80, GREEN);
//, in , down,width,height
if (off_btn.justReleased())
off_btn.drawButton();//renews button background colour
if (off_btn.justPressed()) {
off_btn.drawButton(true);//deletes button background colour
tft.fillRect ( 40 , 80 , 160 , 80 , RED );
//box drawn from (top lft,bot lft,top rt,bot rt,bkgrnd colour
bool Touch_getXY(void)//Touch_getXY() updates global vars
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); //restore shared pins
pinMode(XM, OUTPUT);
digitalWrite(YP, HIGH); //because TFT control pins
digitalWrite(XM, HIGH);
bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
if (pressed) {
pixel_x = map(p.y, TS_LEFT, TS_RT, 0, 480); //landscape
//pixel_x = map(p.y, LEFT=716, RT=591, 0, 480); //landscape
//pixel_x = map(p.x, TS_LEFT, TS_RT, 0, 320); //portrait
//TS_LEFT, TS_RT,
pixel_y = map(p.x, TS_TOP, TS_BOT, 0, 320);//landscape
//pixel_y = map(p.x, TOP=385, BOT=462, 0, 320);//landscape
//pixel_y = map(p.y, TS_TOP, TS_BOT, 0, 480);//portrait
//TS_TOP, TS_BOT,
return pressed;
I have added all my code but the line I am trying to get working is the third from the bottom of the setup.
I have a bitmap called woof.bmp on the micro sd card in the reader.
Would someone mind pointing me in a direction that can help me show bitmaps on the screen?
Thanks,
Bob.
