How do control a actuator with a potentiometer
I'm new to Arduino, I'm working on an Arduino setup with a potentiometer 10k, Arduino Uno, BTS7960, and a Nanotec actuator. I was able to use the potentiometer 10k because it's simple to code, but when I watch and read tutorials on controlling an actuator. One tutorial is very easy to work with some wiring and copy-and-paste codes but the actuator they use had pot feedback while this actuator doesn't have. Another one has BTS7960 and an actuator similar to Nanotec but it uses buttons to control the actuator.
float floatMap(float x, float in_min, float in_max, float out_min, float out_max) {
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
  // initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
  // read the input on analog pin A0:
  int analogValue = analogRead(A0);
  // Rescale to potentiometer's voltage (from 0V to 5V):
  float voltage = floatMap(analogValue, 0, 1023, 0, 5);
  // read the angluar position (from 0 to 270 degree):
  float angle = floatMap(analogValue, 0, 1023, 0, 270);
  // read the actuator position (from 0 to 3 inches):
  float lenght = floatMap(analogValue, 0, 1023, 0, 3);
  Serial.print("Analog: ");
  Serial.print(analogValue);
  Serial.print(", Voltage: ");
  Serial.println(voltage);
  Serial.print(", angle: ");
  Serial.println(angle);
  Serial.print(", length: ");
  Serial.println(lenght);
Nanotec actuator:
Hi Anthony,
welcome to the arduino-forum.
I have never worked with a linear actuator.
So I'm unsure how it works.
My guessing is you apply a bigger or smaller current to the coils and this makes the PIN with the thread move out more or less???
But I'm totally unsire if this is correct.
What is a BTS7960?? You are the one who wants help you should provide a datasheet and a description what a BTS7960 is
And it is always a good idea to describe your whole project. Which means to give an overview about your whole project. This is not boring. It is the opposite: the interesting thing is what is your context?
best regards Stefan
It's a high-current full-bridge motor-driven module that can have a voltage between 6 to 27 V and a max current of 43 A.
OK very good link to the BTS7960
Can you please explain how this linear actuator is working?
And what you want to do in the end with it.
I assume moving the linear actuator back and forth is not only for fun
what is the final purpose of moving the linear actuator?
depending on that purpose it might be sufficient to just switch the coils to move out completely or move in as fast as the actuator can
or maybe controlled in a well defined speed or with different stops in-between
best regards Stefan
kinda risky for a newbie?
That actuator uses a stepper motor, you need a 2 Amp stepper driver like a TB6600 and one of the stepper libraries like AccelStepper.
NOTE: The Arduino "Stepper.h" library will not work with step/direction drivers like TB6600.
https://us.nanotec.com/fileadmin/files/Datenblaetter/Linearaktuatoren/LGA56/LGA56...UQBN/LGA561S20-A-UQBN-019.pdf
If you don't need the full torque permitted by the 2A stepper of the Nanotech linear actuator, you can use a lower current limit setting.
The Pololu DRV8825 is inexpensive and can handle 1.5A/winding without cooling (2.2A/winding with forced air cooling). The standard stepper libraries with STEP/DIR outputs support it.
Do you want to use the potentiometer to control the position of the actuator along the approximately 19mm stroke length?
You will need to translate the range of the pot into steps for the motor.
How do you plan to determine the home position of the actuator? A limit switch at one or both ends is going to be required as moving against fixed limit stops should be avoided.
19mm is short, so yes. I went to start at 0 mm with 0 ohms to 19mm with maybe 70
to 80 ohms.
thanks for mentioning theses libraries
