please help.
I have a router but do not have a public ip. how to make the router and ENC28J60, get online on the internet.
I use the 3g gsm modem connection.
please help.
Please explain why you need a public IP. What do you want to achieve with your ENC28J60?
Why is that relevant? That should be hidden by your router, shouldn't it?
I want to access my arduino from anywhere in the world. how, and my modem does not have a public ip?
and I want only certain ip can access it later. is there any solution?
Your router should support DDNS and port forwarding. Google : dyndns.org and port forwarding.
hi waski.
I do not know anything about linux. My router is using openwrt.
I have not changed anything on my router. Can you help me, so Arduino can be called on my pc first.
because I've been plugging ENC28J60 using the router to rj45, but his ip can not call on my computer?
You better ask how to configure OpenWRT for port forwarding on an OpenWRT forum. There are several versions of OpenWRT and they are not identical in configuration issues, so ask the specialists there. They can also help you filtering out unwanted connections.
Post the code you're using as well as how you configured your network (what IPs, how you plugged stuff, etc.). My crystal ball is out for repair so I'm not able to get that information magically at the moment :).
ok friend.
I would go to the openwrt forum and get what I want.
