I have a setup going where I can use a Bluetooth app called RemoteXY to control the speed of a Turnigy sk3 Aerodrive brushless motor. The slider maps almost perfectly to the spin speed of the motor, however, when I am at the low end of the slider (when the motor should startup spinning slowly), the motor doesn't do anything, and then suddenly jolts and starts spinning after a certain threshold. I think this is known as hesitation or cogging, and it's a common issue with brushless motors from what I can tell.
The question is, is there any way I can smooth out this initial jolt when I start raising the slider, or do I just have to deal with the fact that the startup will not be smooth? After the motor has started up everything seems to roll smoothly.
A video of the issue I am referring to here.
My code is below. The motor control section is near the end, I've indicated it in a comment
// RemoteXY include library //
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__SOFTSERIAL
#include <SoftwareSerial.h>
#include <RemoteXY.h>
//#include <Servo.h>
#include <PWMServo.h>
//Servo ESC; //create servo object
PWMServo ESC;
// RemoteXY connection settings
#define REMOTEXY_SERIAL_RX 10
#define REMOTEXY_SERIAL_TX 11
#define REMOTEXY_SERIAL_SPEED 9600
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
{ 255,2,0,0,0,60,0,11,13,1,
4,0,23,16,17,64,2,26,2,0,
31,5,22,11,2,26,31,31,79,78,
0,79,70,70,0,129,0,5,7,18,
6,17,76,69,68,0,129,0,15,85,
37,6,17,83,101,114,105,97,108,32,
111,117,116,112,117,116,0 };
// this structure defines all the variables and events of your control interface
struct {
// input variables
int8_t slider_1; // =0..100 slider position
uint8_t switch_1; // =1 if switch ON and =0 if OFF
// other variable
uint8_t connect_flag; // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
// END RemoteXY include //
int power = 8;
int ledPin = 2;
RemoteXY_Init ();
digitalWrite(LED_BUILTIN, HIGH);
// TODO you setup code
pinMode (LED_BUILTIN, OUTPUT);
pinMode (power, OUTPUT);
pinMode (ledPin, OUTPUT);
//pinMode (7, OUTPUT);
//int ledMapping;
ESC.attach(12, 1000, 2000); //attach ESC to output from pin 6
//TIMSK5 = 0;
RemoteXY_Handler ();
//THIS SECTION IS FOR BLUETOOTH APP
//Serial.println(RemoteXY.slider_1);
digitalWrite(power, HIGH); //supply power to Bluetooth module through pin 8
//digitalWrite(7, HIGH);
int ledMapping = map(RemoteXY.slider_1, 0, 100, 0, 255);
//Serial.println(ledMapping);
analogWrite(ledPin, ledMapping);
// Motor control starts here
int spinMapping = map(RemoteXY.slider_1, 0, 100, 0, 20); //map the slider to the servo
if (RemoteXY.switch_1 == 1){
ESC.write(95+spinMapping); //write to the ESC the value of mapped slider, 90 being the neutral angle
else if (RemoteXY.switch_1 == 0){
ESC.write(85-spinMapping); //the reverse direction
Any advice would be greatly appreciated!
