How do I add a limit to my load cell
[color=#333333]
[pre] I am using this code to get a reading from an S type Load cell from an Arduino UNO. The amplifier that I am using is HX711. Using this program the serial monitor prints values constantly. I need the serial monitor to report values on between 1 and 2 lbs and ignore the rest
#include "HX711.h"
#define calibration_factor -7050.0 //This value is obtained using the SparkFun_HX711_Calibration sketch
#define LOADCELL_DOUT_PIN 3
#define LOADCELL_SCK_PIN 2
HX711 scale;
Serial.println("HX711 scale demo");
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.set_scale(calibration_factor); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
Serial.println("Readings:");
Serial.print("Reading: ");
Serial.print(scale.get_units(), 1); //scale.get_units() returns a float
Serial.print(" lbs"); //You can change this to kg but you'll need to refactor the calibration_factor
}[/color][/pre]
Well, that could’ve gone better.
Try:
#include "HX711.h"
HX711 scale;
In a metric world, why would you want to use pounds?
What have you tried to filter your results?
