i need multiple sounds too
const int analogPin = A0; // pin that the sensor is attached to
const int ledPin = A1; // pin that the beeper is attached to
const int threshold = 400; // an arbitrary threshold level that's in the range of the analog input
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communications:
// read the value of the potentiometer:
int analogValue = analogRead(analogPin);
// if the analog value is high enough, turn on the LED:
if (analogValue > threshold) {
digitalWrite(ledPin, HIGH);
else {
digitalWrite(ledPin,LOW);
// print the analog value:
Serial.println(analogValue);
delay(1); // delay in between reads for stability
