The ADS1115 sensor is activated and the result is stored in a variable via a specific operation on eight channels.
(It takes about 800 ~ 850ms to reach this point. It will work again in 1 second.) -
Save the sensor value to MODBUS and wait for the call.
Call MODBUS every 1 second to receive the value.
Problem: After receiving the value only for the first time of the call, after a few seconds, the time out error occurs and the value is not received.
Action: The MODBUS wait time is short as 150 ~ 200ms.
Let the ADS1115 sensor run once every 3 seconds
Increased MODBUS call waiting time to 1 second, but call failed
function timing in oscilloscope :
modbus simulator result : (success 358 / time out error 332)
/* Serial */
Serial1.begin(BAUDRATE); // GPS
Serial2.begin(BAUDRATE); // LoRa
Serial.begin(BAUDRATE); // monitor
rtc.begin(DateTime(F(__DATE__), F(__TIME__)));
slave.cbVector[CB_READ_REGISTERS] = readAnalogIn;
// set Serial and slave at baud 9600.
slave.begin( BAUDRATE );
/* Timer */
Timer1.attachInterrupt(COUNT_1MS).start(1000); // every 1ms
Timer2.attachInterrupt(ADC_CAL_START).start(1000000); // every 1s
Timer4.attachInterrupt(SAVE_LORA_BUFFER_AND_SDCARD).start(1000000); // every 1s
Timer5.attachInterrupt(GPS_INIT).start(3600000000); every 1 hour
/* ADC */
analogReadResolution(12);
pinMode(SENSOR_00, INPUT);
pinMode(SENSOR_01, INPUT);
pinMode(SENSOR_02, INPUT);
pinMode(SENSOR_03, INPUT);
pinMode(SENSOR_04, INPUT);
pinMode(SENSOR_05, INPUT);
pinMode(SENSOR_06, INPUT);
pinMode(SENSOR_07, INPUT);
/* ADS1115 */
ads1.getAddr_ADS1115(ADS1115_DEFAULT_ADDRESS); // 0x48, 1001 000 (ADDR = GND)
ads2.getAddr_ADS1115(ADS1115_VDD_ADDRESS); // 0x49, 1001 001 (ADDR = VDD)
ads1.setGain(GAIN_TWO); // 2/3x gain +/- 6.144V 1 bit = 0.1875mV
ads2.setGain(GAIN_TWO);
ads1.setMode(MODE_CONTIN); // Continuous conversion mode
ads2.setMode(MODE_CONTIN); // Continuous conversion mode
ads1.setRate(RATE_250); // 250SPS
ads2.setRate(RATE_250); // 250SPS
ads1.setOSMode(OSMODE_SINGLE); // Set to start a single-conversion
ads2.setOSMode(OSMODE_SINGLE); // Set to start a single-conversion
ads1.begin(); // ADS1115 - 1 start
ads2.begin(); // ADS1115 - 2 start
SDCARD_CHECK_FAIL();
void COUNT_1MS(){
count_value++;
if(count_value == 3000){
ADS1115_oneTime = false;
count_value = 0;
if((ads1115_finish_value >= 1999) && (ads1115_finish_value <= 2001)){
ads1115_finish_value = 0;
if (!LoRaParameter_oneTime && !GPS_oneTime && !Setting_File_SDCARD_oneTime) {
LoRa_SaveBuffer();
else if (LoRaParameter_oneTime && !GPS_oneTime && !Setting_File_SDCARD_oneTime) {
GPS_SaveBuffer();
else if (!Setting_File_SDCARD_oneTime && LoRaParameter_oneTime && GPS_oneTime){
Check_Setting_File_SDCARD();
/*After the first boot, the above if code is not executed and the following code repeats the loop for 3 seconds. */
else if (Setting_File_SDCARD_oneTime){
if (!ADS1115_oneTime) {
ADS1115_SaveBuffer();
}else if(ADS1115_oneTime){
ads1115_finish_value = count_value;
if((ads1115_finish_value > 2001) && (ads1115_finish_value <= 3000)){
slave.poll();
} // loop
I get values at first perfectly, but I get time out error after few seconds, it seems that the timing is still twisted. I do not know how to fix it.
If I remove the ads1115 function, all the sensors will function normally, and even if I call the Modbus value every 100ms, I get a value perfectly without error.
