I tried adding a <while(blink<100){CODE}> but doesn't work
// Which pins are connected to which LED
const byte greenLED = 12;
const byte redLED = 13;
// Time periods of blinks in milliseconds (1000 to a second).
const unsigned long greenLEDinterval = 500;
const unsigned long redLEDinterval = 1000;
// Variable holding the timer value so far. One for each "Timer"
unsigned long greenLEDtimer;
unsigned long redLEDtimer;
void setup ()
pinMode (greenLED, OUTPUT);
pinMode (redLED, OUTPUT);
greenLEDtimer = millis ();
redLEDtimer = millis ();
} // end of setup
void toggleGreenLED ()
if (digitalRead (greenLED) == LOW)
digitalWrite (greenLED, HIGH);
digitalWrite (greenLED, LOW);
// remember when we toggled it
} // end of toggleGreenLED
void toggleRedLED ()
if (digitalRead (redLED) == LOW)
digitalWrite (redLED, HIGH);
digitalWrite (redLED, LOW);
} // end of toggleRedLED
void loop ()
// Handling the blink of one LED.
if ( (millis () - greenLEDtimer) >= greenLEDinterval)
toggleGreenLED ();
// The other LED is controlled the same way. Repeat for more LEDs
if ( (millis () - redLEDtimer) >= redLEDinterval)
toggleRedLED ();
/* Other code that needs to execute goes here.
It will be called many thousand times per second because the above code
does not wait for the LED blink interval to finish. */
} // end of loop
const unsigned long greenLEDinterval = 1000;
int counter=0;
void setup ()
} // end of setup
if(counter<=5){
counter++;
{if(counter<=5){
counter++;
void loop ()
toggleGreenLED ();
toggleRedLED ();
} // end of loop
since green/redLEDtimers are only reset for the counter < 5 case, toggleGreenLED() and toggleRedLED() are called each iteration of loop after the counter exceeds 5.
this results in counter quickly incrementing and wrapping back to zero so that it looks like the counter is never stopping the toggle
counter should only be incremented for the case where the LED is toggled
it's also confusing that the same counter variable is incremented in both routines
