how do I buffer serial to receive words instead of single characters?
Hi everyone,
I'm having trouble with my code.. Here's the background: I've linked up my bluetooth to my phone, and I want to be able to send messages to the arduino. However, when I type to send a word, it sends out the characters individually. So now I'm trying to write code that will buffer the characters and will only print when I type a period. Here's my code:
Any tips? BTW, I'm using 46 because I think that equals the "." yeah? =)
const int SENS_PIN = A0;
const int LED_PIN = 13;
int sensorValue = 0;
int x = 0;
int words[100];
boolean toggle = true;
    pinMode(13, OUTPUT);
    pinMode(2, OUTPUT);
    pinMode(3, OUTPUT);
    digitalWrite(2, LOW);
    digitalWrite(3, HIGH);
  inputbuffer();
void inputbuffer()
  if (Serial.available())
        words[x] = Serial.read();
        if(words[x] = 46)
          int i;
          Serial.print("Got: ");
          for (i = 0; i < x; i++)
          Serial.print(words[i]);
          Serial.println("");
        Serial.print(words[x]);
        digitalWrite(LED_PIN, toggle); // toggle the LED
        toggle = !toggle;
        x = x+1;
Then, why not use '.'?
int words[100];
One does not read ints from the serial port. One does not read words from the serial port.
  inputbuffer();
Could you maybe add a few more useless blank lines?
        if(words[x] = 46)
Assigning 46 to words[x] will always succeed, so the test will always be true. ==?
The words array should have a much better name. The type should be char. After each character is added, a NULL needs to be added after it (but don't increment the index again).
If you properly NULL terminated the array, and it was the right size/type, you wouldn't need a for loop to print it.
At some point, it might be a good idea to reset i to 0.
heyarn:
You could try something like below substituting a . for the , as the word delimiter.
//zoomkat 3-5-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
// CR/LF could also be a delimiter
String readString;
  Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
  //expect a string like wer,qwe rty,123 456,hyre kjhg,
  //or like hello world,who are you?,bye!,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      //do stuff
      Serial.println(readString); //prints string to serial port out
      readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
This is does not directly answer your question, but if you are trying to control your project via text commands over a serial interface I have developed a library that might interest you.
Its called CommandLine and gives you a unix or dos like command line interface on your serial port or any device that implements the Arduino Stream interface.
You can get the release from http://dl.dropbox.com/u/8923652/CommandLine-1.0.zip or follow the project on Github at GitHub - hackerjones/arduino-commandline: Command line processor for Arduino
Cheers,
Mark
