I am using Sparkfun BME280 sample code to read the BME280 and my Altitude is off for my location. My location was verified by actual location and GPS location The BME280 is reading 40ft low.
I have attached the code:
I2C_ReadAllData.ino
BME280 Arduino and Teensy example
Marshall Taylor @ SparkFun Electronics
May 20, 2015
https://github.com/sparkfun/SparkFun_BME280_Arduino_Library
This sketch configures the BME280 to read all measurements. The sketch also
displays the BME280's physical memory and what the driver perceives the
calibration words to be.
Resources:
Uses Wire.h for I2C operation
Uses SPI.h for SPI operation
Development environment specifics:
Arduino IDE 1.6.4
Teensy loader 1.23
This code is released under the [MIT License](http://opensource.org/licenses/MIT).
Please review the LICENSE.md file included with this example. If you have any questions
or concerns with licensing, please contact techsupport@sparkfun.com.
Distributed as-is; no warranty is given.
#include <stdint.h>
#include "SparkFunBME280.h"
//Library allows either I2C or SPI, so include both.
#include "Wire.h"
//#include "SPI.h"
//Global sensor object
BME280 mySensor;
//***Driver settings********************************//
//commInterface can be I2C_MODE or SPI_MODE
//specify chipSelectPin using arduino pin names
//specify I2C address. Can be 0x77(default) or 0x76
//For I2C, enable the following and disable the SPI section
mySensor.settings.commInterface = I2C_MODE;
mySensor.settings.I2CAddress = 0x76;
//For SPI enable the following and dissable the I2C section
//mySensor.settings.commInterface = SPI_MODE;
//mySensor.settings.chipSelectPin = 10;
//***Operation settings*****************************//
//renMode can be:
// 0, Sleep mode
// 1 or 2, Forced mode
// 3, Normal mode
mySensor.settings.runMode = 3; //Normal mode
//tStandby can be:
// 0, 0.5ms
// 1, 62.5ms
// 2, 125ms
// 3, 250ms
// 4, 500ms
// 5, 1000ms
// 6, 10ms
// 7, 20ms
mySensor.settings.tStandby = 0;
//filter can be off or number of FIR coefficients to use:
// 0, filter off
// 1, coefficients = 2
// 2, coefficients = 4
// 3, coefficients = 8
// 4, coefficients = 16
mySensor.settings.filter = 0;
//tempOverSample can be:
// 0, skipped
// 1 through 5, oversampling *1, *2, *4, *8, *16 respectively
mySensor.settings.tempOverSample = 1;
//pressOverSample can be:
// 0, skipped
mySensor.settings.pressOverSample = 1;
//humidOverSample can be:
// 0, skipped
mySensor.settings.humidOverSample = 1;
Serial.begin(57600);
Serial.print("Program Started\n");
Serial.print("Starting BME280... result of .begin(): 0x");
//Calling .begin() causes the settings to be loaded
delay(10); //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up.
Serial.println(mySensor.begin(), HEX);
Serial.print("Displaying ID, reset and ctrl regs\n");
Serial.print("ID(0xD0): 0x");
Serial.println(mySensor.readRegister(BME280_CHIP_ID_REG), HEX);
Serial.print("Reset register(0xE0): 0x");
Serial.println(mySensor.readRegister(BME280_RST_REG), HEX);
Serial.print("ctrl_meas(0xF4): 0x");
Serial.println(mySensor.readRegister(BME280_CTRL_MEAS_REG), HEX);
Serial.print("ctrl_hum(0xF2): 0x");
Serial.println(mySensor.readRegister(BME280_CTRL_HUMIDITY_REG), HEX);
Serial.print("\n\n");
Serial.print("Displaying all regs\n");
uint8_t memCounter = 0x80;
uint8_t tempReadData;
for(int rowi = 8; rowi < 16; rowi++ )
Serial.print("0x");
Serial.print(rowi, HEX);
Serial.print("0:");
for(int coli = 0; coli < 16; coli++ )
tempReadData = mySensor.readRegister(memCounter);
Serial.print((tempReadData >> 4) & 0x0F, HEX);//Print first hex nibble
Serial.print(tempReadData & 0x0F, HEX);//Print second hex nibble
Serial.print(" ");
memCounter++;
Serial.print("\n");
Serial.print("Displaying concatenated calibration words\n");
Serial.print("dig_T1, uint16: ");
Serial.println(mySensor.calibration.dig_T1);
Serial.print("dig_T2, int16: ");
Serial.println(mySensor.calibration.dig_T2);
Serial.print("dig_T3, int16: ");
Serial.println(mySensor.calibration.dig_T3);
Serial.print("dig_P1, uint16: ");
Serial.println(mySensor.calibration.dig_P1);
Serial.print("dig_P2, int16: ");
Serial.println(mySensor.calibration.dig_P2);
Serial.print("dig_P3, int16: ");
Serial.println(mySensor.calibration.dig_P3);
Serial.print("dig_P4, int16: ");
Serial.println(mySensor.calibration.dig_P4);
Serial.print("dig_P5, int16: ");
Serial.println(mySensor.calibration.dig_P5);
Serial.print("dig_P6, int16: ");
Serial.println(mySensor.calibration.dig_P6);
Serial.print("dig_P7, int16: ");
Serial.println(mySensor.calibration.dig_P7);
Serial.print("dig_P8, int16: ");
Serial.println(mySensor.calibration.dig_P8);
Serial.print("dig_P9, int16: ");
Serial.println(mySensor.calibration.dig_P9);
Serial.print("dig_H1, uint8: ");
Serial.println(mySensor.calibration.dig_H1);
Serial.print("dig_H2, int16: ");
Serial.println(mySensor.calibration.dig_H2);
Serial.print("dig_H3, uint8: ");
Serial.println(mySensor.calibration.dig_H3);
Serial.print("dig_H4, int16: ");
Serial.println(mySensor.calibration.dig_H4);
Serial.print("dig_H5, int16: ");
Serial.println(mySensor.calibration.dig_H5);
Serial.print("dig_H6, uint8: ");
Serial.println(mySensor.calibration.dig_H6);
//Each loop, take a reading.
//Start with temperature, as that data is needed for accurate compensation.
//Reading the temperature updates the compensators of the other functions
//in the background.
Serial.print("Temperature: ");
Serial.print(mySensor.readTempC(), 2);
Serial.println(" degrees C");
Serial.print(mySensor.readTempF(), 2);
Serial.println(" degrees F");
Serial.print("Pressure: ");
Serial.print(mySensor.readFloatPressure(), 2);
Serial.println(" Pa");
Serial.print("Altitude: ");
Serial.print(mySensor.readFloatAltitudeMeters(), 2);
Serial.println("m");
Serial.print(mySensor.readFloatAltitudeFeet(), 2);
Serial.println("ft");
Serial.print("%RH: ");
Serial.print(mySensor.readFloatHumidity(), 2);
Serial.println(" %");
