How do i call a static member inside a static method using class ?
The logic is just to get the code working with the static methods. I am getting “undefined reference to” error how do call static members inside the methods inside a class?
The code looks like this#
class ResetValueTimer{
public :
static unsigned long calledTimeString;
static int stringCalled ;
static String resetIn(String from, String to, unsigned long seconds){
if(!ResetValueTimer::stringCalled){
ResetValueTimer::calledTimeString = millis();
ResetValueTimer::calledTimeString = 1;
if(millis() - ResetValueTimer::calledTimeString >= seconds){
ResetValueTimer::stringCalled = 0;
return to;
return from;
void setup(){
String foo= “HELLO WORLD”;
String boo = “BYE WORLD”;
void loop(){
foo= ResetValueTimer::resetIn(foo,boo,2000);
boo= ResetValueTimer::resetIn(boo,“NOTHING NOT CHANGE”,2000);
Serial.print("foo : “);
Serial.print(millis()/60);
Serial.print(”: "+foo);
Serial.print("| boo : “);
Serial.println(”: "+boo);
You 'defined' them but did not 'declare' them.
class ResetValueTimer {
  public :
    static int stringCalled;
    static String resetIn(String from, String to, unsigned long interval) {
      if (!stringCalled) {
      if (millis() - calledTimeString  >= interval) {
        stringCalled = 0;
        return to;
      return from;
unsigned long ResetValueTimer::calledTimeString;
int ResetValueTimer::stringCalled;
String foo = "HELLO WORLD";
String boo = "BYE WORLD";
  foo = ResetValueTimer::resetIn(foo, boo, 2000);
  boo = ResetValueTimer::resetIn(boo, "NOTHING NOT CHANGE", 2000);
  Serial.print("foo : ");
  Serial.print(millis() / 60);
  Serial.print(": " + foo);
  Serial.print("| boo : ");
  Serial.println(": " + boo);
