Hi
I design custom Atmega2560 board and I need access pin PD6.
Thank you
Hi
Thank you
Use direct port access via PORTD, PIND, DDRD and _BV(PD6).
You might like MegaCore:
It defines Arduino pin numbers for all the IO pins on the ATmega2560:
It also uses optiboot, which frees up 7 kB of flash memory without any downsides. True, flash memory is not often in shortage on the ATmega2560, but it never hurts to have an extra 7 kB to play with!
Thanks, I have tried all but not working
pin 24, 40,PIN_PD6,DDRD = B11111111; PORTD = B11111111; non works
// Serial1.begin(115200);
// Serial1.println("Test");
portMode(24,OUTPUT);
portWrite(24,HIGH);
portWrite(24,HIGH);
I build custom ATmega2560 board with no crystal and I want use Megacore to program it but nothing happen after successful program
All I want to do turn on LED on port PD6(or any other pin), which I have tried pin 79, PIN_PD6,PORTD = B11111111; and not working
I have upload bootloader using megacode below: (First try with internal clock)
// make atmega2560 AVR_FREQ=8000000L BAUD_RATE=115200 UART=0 LED=B7 LED_START_FLASHES=2 -BIGBOOT
portMode(40,OUTPUT);
portWrite(PIN_PD6,HIGH);
Topics merged
Why did you start a second one ?
This is different questions one was related how to access PD6 the other one is how to use MEGA core, since every time I put UART in bootloader nothing happen but when I select No bootloader it works
Problem Solved Thanks
