how do I cause a function of my code to stop running when another one runs.
I’m creating a car that uses a solenoid valve to move and a magnetometer to direct it self to a specific location . every time the solenoid fires it creates a magnetic field that gives a wrong reading for the magnetometer since its a compass. how can i stop the magnetometer from send values or the arduinos from recieving values from the magnetometer when the solinoid fires. this is my code.
#include <Servo.h>
#include <Wire.h>
#include <LSM303.h>
LSM303 compass;
Servo myservo;
int DISTANCE=0;
int servoPin = 3; // Pin that the servomotor is connected to
int solenoidPin = 2; // Pin that the mosfet is conected to
int switchPin = 4; // Pin that the switch is conected to
int pos = 0; // variable to store the servo position
int switchState;
int servoDir = 0;
int solenoidState = LOW;
unsigned long previousMillis = 0; // will store last time LED was updated
const long interval = 1000; // interval at which to blink (milliseconds)
myservo.attach(servoPin); // attaches the servo on pin 9 to the servo object
pinMode(solenoidPin, OUTPUT); //Sets the pin as an output
pinMode(switchPin, INPUT_PULLUP); //Sets the pin as an input_pullup
Serial.begin(9600); // starts serial communication @ 9600 bps
Wire.begin();
compass.init();
compass.enableDefault();
////////////// MAGNETOMETER ///////////////////////////////////////////////////
compass.read();
float heading = compass.heading();
////////////// SERVOMOTOR ///////////////////////////////////////////////////
if(heading>=230 && heading<=250)
pos=90;
if(heading>250)
pos=45;
if (heading<230)
pos=135;
myservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(10);
////////////// SOLENOID VALVE ///////////////////////////////////////////////////
if (currentMillis - previousMillis >= interval) {
if (solenoidState == LOW) {
solenoidState = HIGH;
digitalWrite(solenoidPin, solenoidState); //Switch Solenoid ON/oFF
////////////// REED SWITCH ///////////////////////////////////////////////////
switchState = digitalRead(switchPin);
if (switchState==1)
DISTANCE=DISTANCE+10;
////////////// Distance ///////////////////////////////////////////////////////
////////////// Serial Print ///////////////////////////////////////////////////
Serial.print(“Reed Switch: “);
Serial.print(switchState);
Serial.print(” Magnetometer: “);
Serial.println( heading );
//Serial.print(” Distance”);
// Serial.println(DISTANCE);
delay(100);
Below as a public service :wink: is the OP’s code in code tags, with the white space tidied up a bit, and the { and } on their own lines, and control-T’d for formatting:
#include <Servo.h>
#include <Wire.h>
#include <LSM303.h>
LSM303 compass;
Servo myservo;
int DISTANCE = 0;
int switchState;
int servoDir = 0;
  Wire.begin();
  compass.init();
  compass.read();
  if (heading >= 230 && heading <= 250)
    pos = 90;
  if (heading > 250)
    pos = 45;
  if (heading < 230)
    pos = 135;
  myservo.write(pos);              // tell servo to go to position in variable 'pos'
  delay(10);
  if (switchState == 1)
    DISTANCE = DISTANCE + 10;
  Serial.print("Reed Switch: ");
  Serial.print("   Magnetometer: ");
  //Serial.print(" Distance");
  delay(100);
