Here is the script
#include <SoftwareSerial.h>
#include <Wire.h> // Bibliothque pour l'I2C
#include "RTClib.h" // Bibliothque pour le module RTC
RTC_DS1307 RTC;
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN 6 // On Trinket or Gemma, suggest changing this to 1
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 24 // Popular NeoPixel ring size
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
uint32_t vert = pixels.Color(0, 250, 0);
uint32_t orange = pixels.Color(250, 250, 0);
uint32_t rouge = pixels.Color(255, 0, 0);
SoftwareSerial pmsSerial(2, 3);
const uint8_t cs = 10;
const uint8_t dc = 9;
const uint8_t rst = 8; // you can also connect this to the Arduino reset
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library resolution 128X160
#include <SPI.h>
#include<SD.h>
const int cs_sd=4;
int temps; // temps d'acquisition
double tempsInit; // initialisation du timer au dmarrage du loop()
#if defined(__SAM3X8E__)
#undef __FlashStringHelper::F(string_literal)
#define F(string_literal) string_literal
#endif
// Option 1: use any pins but a little slower
//Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, mosi, sclk, rst);
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, rst);
float nombre_leds=0;
int x=2;
// Initialise la liaison I2C
Wire.begin();
// Initialise le module RTC
RTC.begin();
Serial.print("init SD");
if(!SD.begin(cs_sd)) //Condition vrifiant si la carte SD est prsente dans l'appareil
Serial.print("Defaut SD");
return;
Serial.print("Carte SD OK");
File data = SD.open("donnees.txt",FILE_WRITE); // Ouvre le fichier "donnees.txt"
data.println(""); data.println("Dmarrage acquisition"); // Ecrit dans ce fichier
data.close();
tft.initR(INITR_GREENTAB); // initialize a ST7735S chip, black tab
Serial.println("init");
// our debugging output
tft.fillScreen(ST7735_BLACK);
// sensor baud rate is 9600
pmsSerial.begin(9600);
pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
pixels.setBrightness(2);
struct pms5003data {
uint16_t framelen;
uint16_t pm10_standard, pm25_standard, pm100_standard;
uint16_t pm10_env, pm25_env, pm100_env;
uint16_t particles_03um, particles_05um, particles_10um, particles_25um, particles_50um, particles_100um;
uint16_t unused;
uint16_t checksum;
struct pms5003data data;
pixels.clear(); // Set all pixel colors to 'off'
DateTime now=RTC.now(); //Rcupre l'heure et le date courante
affiche_date_heure(now);
temps = ((millis() - tempsInit))/1000 ; // Dmarrage du chrono
if (readPMSdata(&pmsSerial)) {
tft.setCursor(10, 17);
tft.setTextColor(ST7735_GREEN,ST7735_BLACK);
tft.setTextSize(1);
tft.setCursor(10, 29);
tft.print("0.3 um ");tft.setTextColor(ST7735_CYAN,ST7735_BLACK);tft.print(data.particles_03um);
courbe();
tft.setCursor(10, 41);
tft.setTextSize(1);
tft.print("0.5 um ");tft.setTextColor(ST7735_CYAN,ST7735_BLACK);tft.print(data.particles_05um);
tft.setCursor(10, 53);
tft.setTextSize(1);
tft.print("1.0 um ");tft.setTextColor(ST7735_CYAN,ST7735_BLACK);tft.print(data.particles_10um);
tft.setCursor(10, 65);
tft.setTextSize(1);
tft.print("2.5 um ");tft.setTextColor(ST7735_CYAN,ST7735_BLACK);tft.print(data.particles_25um);
tft.setCursor(10, 77);
tft.setTextSize(1);
tft.print("5.0 um ");tft.setTextColor(ST7735_CYAN,ST7735_BLACK);tft.print(data.particles_50um);
tft.setCursor(10, 89);
tft.setTextSize(1);
tft.print("10.0 um ");tft.setTextColor(ST7735_CYAN,ST7735_BLACK);tft.print(data.particles_100um);
tft.setCursor(10, 101);
tft.setTextSize(1);
tft.print("PM 10 ");tft.setTextColor(ST7735_CYAN,ST7735_BLACK);tft.print(data.pm100_standard);tft.setTextColor(ST7735_GREEN,ST7735_BLACK);tft.print(" mic/m3 ");
tft.drawLine(0,113,0,158,ST7735_RED);
tft.drawLine(0,158,128,158,ST7735_RED);
nombre_leds =int (((float (data.particles_03um)/65535)*24));
//nombre_leds =(8);
Serial.println (nombre_leds);
if ((nombre_leds<=8) and (nombre_leds>=1)){
pixels.fill(vert , 0, nombre_leds);
else if ((nombre_leds<=16) and (nombre_leds>=8)) {
pixels.fill(vert , 0, 8);
pixels.fill(orange , 8, ((nombre_leds)-8));
else if (nombre_leds>16) {
pixels.fill(orange , 8, 8);
pixels.fill(rouge , 16, ((nombre_leds)-16));
else if (nombre_leds<=1) {
pixels.fill(vert , 0, 1);
pixels.show(); // Send the updated pixel colors to the hardware.
// Dfinition donnes
String PM03=String(data.particles_03um);
String PM05=String(data.particles_05um);
String PM10=String(data.particles_10um);
String PM25=String(data.particles_25um);
String PM50=String(data.particles_50um);
String PM100=String(data.particles_100um);
String PMS10=String(data.pm10_standard);
String PMS25=String(data.pm25_standard);
String PMS100=String(data.pm100_standard);
String Temps=String(temps);
//Ecriture des donnes dans le fichier texte
File data=SD.open("donnees.txt",FILE_WRITE);
data.println( Temps + " " + PM03+ " " + PM05 +" " +PM10+" " +PM25+" "+PM50+" " +PM100+" "+PMS10+" "+PMS25+" "+PMS100+" ");
data.close();
boolean readPMSdata(Stream *s) {
if (! s->available()) {
return false;
// Read a byte at a time until we get to the special '0x42' start-byte
if (s->peek() != 0x42) {
s->read();
return false;
// Now read all 32 bytes
if (s->available() < 32) {
return false;
uint8_t buffer[32];
uint16_t sum = 0;
s->readBytes(buffer, 32);
// get checksum ready
for (uint8_t i=0; i<30; i++) {
sum += buffer[i];
// The data comes in endian'd, this solves it so it works on all platforms
uint16_t buffer_u16[15];
for (uint8_t i=0; i<15; i++) {
buffer_u16[i] = buffer[2 + i*2 + 1];
buffer_u16[i] += (buffer[2 + i*2] << 8);
// put it into a nice struct :)
memcpy((void *)&data, (void *)buffer_u16, 30);
if (sum != data.checksum) {
Serial.println("Checksum failure");
return false;
// success!
return true;
//Converti le numro de jour en jour /!\la semaine commence un dimanche
String donne_jour_semaine(uint8_t j){
switch(j){
case 0: return "DIM";
case 1: return "LUN";
case 2: return "MAR";
case 3: return "MER";
case 4: return "JEU";
case 5: return "VEN";
case 6: return "SAM";
default: return " ";
// affiche la date et l'heure sur l'cran
void affiche_date_heure(DateTime datetime){
// Date
String jour = donne_jour_semaine(datetime.dayOfTheWeek()) + " " +
Vers2Chiffres(datetime.day())+ "/" +
Vers2Chiffres(datetime.month())+ "/" +
String(datetime.year(),DEC);
// heure
String heure = "";
heure = Vers2Chiffres(datetime.hour())+ ":" +
Vers2Chiffres(datetime.minute())+ ":" +
Vers2Chiffres(datetime.second());
data.print(jour + " " + heure+" " );
data.close();
tft.setCursor(18, 5);
tft.setTextSize(1);
tft.setTextColor(ST7735_CYAN,ST7735_BLACK);tft.print(jour);
tft.setCursor(30, 17);tft.setTextColor(ST7735_CYAN,ST7735_BLACK);tft.print(heure);
//permet d'afficher les nombres sur deux chiffres
String Vers2Chiffres(byte nombre) {
String resultat = "";
if(nombre < 10)
resultat = "0";
return resultat += String(nombre,DEC);
void courbe() {
int nouvelleValeur03;
int nouvelleValeur05;
int nouvelleValeur10;
int nouvelleValeur25;
int nouvelleValeur50;
nouvelleValeur03 = map((data.particles_03um), 2, 65535, 158, 113);
nouvelleValeur05 = map((data.particles_05um), 2, 65535, 158, 113);
nouvelleValeur10 = map((data.particles_10um), 2, 65535, 158, 113);
nouvelleValeur25 = map((data.particles_25um), 2, 65535, 158, 113);
nouvelleValeur50 = map((data.particles_50um), 2, 65535, 158, 113);
x++;
tft.drawPixel(x,nouvelleValeur03,ST7735_CYAN);
tft.drawPixel(x,nouvelleValeur05,ST7735_YELLOW);
tft.drawPixel(x,nouvelleValeur10,ST7735_RED);
tft.drawPixel(x,nouvelleValeur25,ST7735_WHITE);
tft.drawPixel(x,nouvelleValeur50,ST7735_BLUE);
if (x>123) {
x=2;
tft.fillRect(2,113,126,45,ST7735_BLACK);
How do i make it print data? I don't have a sd card or a part where i can insert one.
