How do I change the speed of fading with Tlc5940?
Hey, fresh meat here! I´ve just recently discovered Arduino and could use some help. I´m going to have 32 LEDs fading with seperate speeds in a organic way. I´ve been using example codes for some hours now, but the fading is way too rapid. I don´t know how to make a single LED to fade slow and smooth. Can you help me?
Below is the code I´m using right now, testing one LED. How do make the fading slower here?
#include "Tlc5940.h"
#include "tlc_fades.h"
TLC_CHANNEL_TYPE channel;
  Tlc.init();
  if (tlc_fadeBufferSize < TLC_FADE_BUFFER_LENGTH - 2) {
    if (!tlc_isFading(1)){
      uint16_t duration = 3000 - (analogRead(0) * 2);
      int maxValue = 4000;
      uint32_t startMillis = millis();
      uint32_t endMillis = startMillis + duration;
      tlc_addFade(1, 0, maxValue, startMillis, endMillis);
      tlc_addFade(1, maxValue, 0, endMillis, endMillis + duration);
    if (channel++ == NUM_TLCS * 16) {
      channel = 0;
  tlc_updateFades();
I'd think that you could change the speed of fading by changing 'duration'. Currently it is set by an analog input on A0:
That will get you between 954 milliseconds (about a second) and 3000 milliseconds (three seconds).
You can make the decay time a constant:
      unsigned long duration = 10000; // Decay over 10 seconds
Thank you johnwasser! Great...
Now, if I don´t want a total fade out, so that the LEDs never go down to zero, how do I make that happend?
kraken667: Now, if I don´t want a total fade out, so that the LEDs never go down to zero, how do I make that happend?
I'd guess that you'd set the start or end point of the fade to something other than zero.
Thanks again! Sorry for being such a neebie...
