How do i code this correctly?
I have a thermal printer, also a force resistant sensor
using the coding from the library i thought it would go something like this
if (fsrReading < 10) {
  printer.justify('L');
  printer.println("print word");
  }  else if (fsrReading > 10) {
  printer.println("print word2");
It’s probably going to be completely wrong as i’m new to all this.
What happens if fsrReading is exactly 10?
And? What happened?
I didn’t think of that, i have no idea.
  }  else if (fsrReading > 9) {
Would that work better?
In response to the second question
printertest.cpp: In function ‘void setup()’:
printertest.pde:-1: error: ‘fsrVoltage’ was not declared in this scope
I get that error when i put the code in… the full code is as follows
#if ARDUINO >= 100
 #include "SoftwareSerial.h"
#else
 #include "NewSoftSerial.h"
#endif
#include "Thermal.h"
#include "adalogo.cpp"
#include "adaqrcode.cpp"
int printer_RX_Pin = 2;  // this is the green wire
int printer_TX_Pin = 3;  // this is the yellow wire
int fsrAnalogPin = 0; // FSR is connected to analog 0
Thermal printer(printer_RX_Pin, printer_TX_Pin);
void setup(){
  printer.begin();
  }  else if (fsrReading < 200) {
  printer.sleep(); //Tell printer to sleep. MUST call wake before printing again, even if reset
  printer.wake(); //Wake printer.
  printer.setDefault(); //set printer to defaults. ****WILL FEED SEVERAL LINES WHEN CALLED***
void loop(){
if(fsrReading > 10)
  // It is...
   // It is not...
printertest.cpp: In function 'void setup()': printertest.pde:-1: error: 'fsrVoltage' was not declared in this scope
So, where is fsrVoltage (or fsrReading, for that matter) declared and valued?
If i knew i don't think i'd be in this predicament, like i said i'm completely new, i thought it'd work the same way as some other coding languages do but clearly not.
I think i copied the wrong error, this is the error i'm getting, there is no voltage just reading
printertest2.cpp: In function 'void setup()':
printertest2:30: error: 'fsrReading' was not declared in this scope
But as i said, i don't know where to declare or value it.
What other languages allow you to make up variables on the fly?
What other languages allow you to assume that a variable like fsrReading will be bound, without explicitly saying so, to the state of some piece of hardware?
You need to declare fsrReading as a global int. As such, it will be valued automatically, with a value appropriate for it's type (0 in the case of ints).
In setup() or loop(), where you use fsrReading, you need to assign it a value:
fsrReading = analogRead(fsrPin);
Make sure that you declare and value (the default won't work) fsrPin (it's where you connect the fsr).
Thank got it printing again, thank you! I'm new to this, i didn't realise it had to be declared at the top.
