How do i combine 2 codes in 1 Arduino mega? (capping machine)
Hey, I have 2 separate codes for my capping machine that i need to combine into 1 for my Arduino Mega. The first code is for a LCD display to count the cap's in the holister and the second one is for the machine that tightens the caps.
I want 2 combine the 2 codes into 1 for my Arduino Mega...
What is the best way to combine the 2?
Or is there someone that can put them together for me?
Thank you in advance! :slight_smile:
CODE 1 (Display Cap Counter)
//YWROBOT
//Compatible with the Arduino IDE 1.0
//Library version:1.1
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3F,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
// this constant won't change:
const int Up_buttonPin = 2; // the pin that the pushbutton is attached to
const int Down_buttonPin = 3;
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int up_buttonState = 0; // current state of the up button
int up_lastButtonState = 0; // previous state of the up button
int down_buttonState = 0; // current state of the up button
int down_lastButtonState = 0; // previous state of the up button
bool bPress = false;
pinMode( Up_buttonPin , INPUT_PULLUP);
pinMode( Down_buttonPin , INPUT_PULLUP);
lcd.init(); // initialize the lcd
// Print a message to the LCD.
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Please Select:");
lcd.setCursor(2,1);
lcd.print(buttonPushCounter);
checkUp();
checkDown();
if( bPress){
   bPress = false;
  lcd.setCursor(2,1);
  lcd.print("               ");
  lcd.setCursor(2,1);
void checkUp()
up_buttonState = digitalRead(Up_buttonPin);
// compare the buttonState to its previous state
if (up_buttonState != up_lastButtonState) {
// if the state has changed, increment the counter
if (up_buttonState == LOW) {
    bPress = true;
  // if the current state is HIGH then the button went from off to on:
  buttonPushCounter++;
  Serial.println("on");
  Serial.print("number of button pushes: ");
  Serial.println(buttonPushCounter);
  // if the current state is LOW then the button went from on to off:
  Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state, for next time through the loop
up_lastButtonState = up_buttonState;
void checkDown()
down_buttonState = digitalRead(Down_buttonPin);
if (down_buttonState != down_lastButtonState) {
if (down_buttonState == LOW) {
    bPress = true;
  buttonPushCounter--;
delay(50);
down_lastButtonState = down_buttonState;
CODE 2 (Cap Tightener and Conveyor)
int motor1pin1 = 2;
int motor1pin2 = 3;
int motor2pin1 = 4;
int motor2pin2 = 5;
int motor3pin1 = 6;
int motor3pin2 = 7;
int motor1ENA = 9;
int motor2ENB = 10;
int motor3ENA = 11;
pinMode (12, INPUT);
pinMode (13, INPUT);
pinMode (motor1pin1, OUTPUT);
pinMode (motor1pin2, OUTPUT);
pinMode (motor2pin1, OUTPUT);
pinMode (motor2pin2, OUTPUT);
pinMode (motor3pin1, OUTPUT);
pinMode (motor3pin2, OUTPUT);
pinMode (motor1ENA, OUTPUT);
pinMode (motor2ENB, OUTPUT);
pinMode (motor3ENA, OUTPUT);
//Controling speed (0 = off and 255 = max speed):
analogWrite(motor1ENA, 250); // ENA pin
analogWrite(motor2ENB, 250); // ENB pin
analogWrite(motor3ENA, 250); // ENA pin
//Controlling spin direction of motors:
if (digitalRead(12) == HIGH){
digitalWrite(motor1pin1, HIGH);
digitalWrite(motor1pin2, LOW);
else{
digitalWrite(motor1pin1, LOW);
if (digitalRead(13) == HIGH){
digitalWrite(motor2pin1, HIGH);
digitalWrite(motor2pin2, LOW);
digitalWrite(motor3pin1, HIGH);
digitalWrite(motor3pin2, LOW);
delay(2000); // Wait for 2000 millisecond(s)
digitalWrite(motor2pin1, LOW);
delay(4000); // Wait for 4000 millisecond(s)
digitalWrite(motor3pin1, LOW);
digitalWrite(motor2pin2, HIGH);
delay(5000); // Wait for 5000 millisecond(s)
else{
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Get rid of all the delays.
Come up with a sound specification.
Tell us what the pins are wired to - don't make us guess.
Post your best effort, or advertise in the "jobs and paid consultancy" section.
Remember to use code tags when posting code.
Count the cap's what?
What is a "holister"?
by replacing the delay()s with non-blocking timing based on millis().
The best way to combine the two sketches is to follow these instructions
for more details
https://www.google.de/search?as_q=arduino+merge+two+sketches
best regards Stefan
