This is my chronometer sketch with 7 segment display and i want to use a button in it as switch(on/off)
code 1 is my chronometer sketch (working)
void setup(){
pinMode(0,OUTPUT);
pinMode(1,OUTPUT);
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
void loop(){
int i;
for( i = 0; i < 10; i++)
ShowNumber(i);
void ShowNumber(int number)
switch(number)
case 0:
digitalWrite(0,LOW);
digitalWrite(1,LOW);
digitalWrite(2,LOW);
digitalWrite(3,LOW);
digitalWrite(4,LOW);
digitalWrite(5,LOW);
digitalWrite(6,HIGH);
case 1:
digitalWrite(0,HIGH);
digitalWrite(3,HIGH);
digitalWrite(4,HIGH);
digitalWrite(5,HIGH);
case 2:
digitalWrite(2,HIGH);
digitalWrite(6,LOW);
case 3:
case 4:
case 5:
digitalWrite(1,HIGH);
case 6:
case 7:
case 8:
case 9:
code 2 is my switch sketch
Debounce
Each time the input pin goes from LOW to HIGH (e.g. because of a push-button
press), the output pin is toggled from LOW to HIGH or HIGH to LOW. There's
a minimum delay between toggles to debounce the circuit (i.e. to ignore
noise).
The circuit:
* LED attached from pin 13 to ground
* pushbutton attached from pin 2 to +5V
* 10K resistor attached from pin 2 to ground
* Note: On most Arduino boards, there is already an LED on the board
connected to pin 13, so you don't need any extra components for this example.
created 21 November 2006
by David A. Mellis
modified 3 Jul 2009
by Limor Fried
http://www.arduino.cc/en/Tutorial/Debounce
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPingreen = 13; // the number of the LED pin
const int ledPinred = 9; // the number of the LED pin
const int ledPinblue = 11; // the number of the LED pin
const int ledPinyellow = 10; // the number of the LED pin
// Variables will change:
int ledState = LOW; // the current state of the output pin
int lastButtonState = LOW; // the previous reading from the input pin
int lastReading= LOW;
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
pinMode(buttonPin, INPUT);
pinMode(ledPingreen, OUTPUT);
pinMode(ledPinred, OUTPUT);
pinMode(ledPinblue, OUTPUT);
pinMode(ledPinyellow, OUTPUT);
// read the state of the switch into a local variable:
int reading = digitalRead(buttonPin);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastReading) {
// reset the debouncing timer
lastDebounceTime = millis();
// save the reading. Next time through the loop,
// it'll be lastReading:
lastReading = reading;
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so accept the button state change:
// toggle the LED if the state of the button changes from LOW to HIGH:
if (lastButtonState == LOW && reading == HIGH) {
if (ledState == HIGH) {
ledState = LOW;
ledState = HIGH;
digitalWrite(ledPingreen, ledState);
digitalWrite(ledPinred, ledState);
digitalWrite(ledPinblue, ledState);
digitalWrite(ledPinyellow, ledState);
lastButtonState = reading;
code 3 is my combine
const int buttonPin = 8;
int lastReading = LOW;
boolean basla = true;
pinMode(0,OUTPUT);
pinMode(1,OUTPUT);
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
if(reading != lastReading)
if((millis() - lastDebounceTime) > debounceDelay)
if(lastButtonState == LOW && reading == HIGH)
if(basla == true)
basla = false;
basla = true;
if(basla == true)
for (int i=0; i < 10; i++)
say(i);
void say(int rakam)
switch(rakam)
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
case 9:
and its not workin what i m missing here?
