First Arduino sketch:
#include<SoftwareSerial.h>
SoftwareSerial BT(10,11); // Connect Tx to pin 10 and Rx to pin 11 of HC-05/HC-06
String readData; // String for storing data send from the Bluetooth device
int Relay1=12;
int val1=0;
BT.begin(9600);
pinMode(Relay1,OUTPUT);
digitalWrite(Relay1,HIGH);
while (BT.available())
delay(10);
char c=BT.read();
readData +=c;
if(readData.length()>0)
Serial.println(readData);
if (readData=="relay1")
val1=digitalRead(Relay1);
if(val1==0)
val1=1;
digitalWrite(Relay1,LOW);
val1=0;
delay(200);
readData="";
THIS PROGRAMME WILL THE DOOR UNLOCK VIA BLUETOOTH
Second Arduino sketch:
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> Fingerprint sensor : ID 751 : $49.95 : Adafruit Industries, Unique & fun DIY electronics and kits
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
// On Leonardo/Micro or others with hardware serial, use those! #0 is green wire, #1 is white
// uncomment this line:
// #define mySerial Serial1
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// comment these two lines if using hardware serial
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
// pinMode(11,OUTPUT);
// pinMode(12,OUTPUT);
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit finger detect test");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
finger.getTemplateCount();
Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
Serial.println("Waiting for valid finger...");
void loop() // run over and over again
getFingerprintIDez();
delay(50); //don't ned to run this at full speed.
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
pinMode(12,OUTPUT);
if(finger.fingerID==1)
digitalWrite(12,LOW);
digitalWrite(12,HIGH);
// if(finger.fingerId==2)
// digitalWrite(13,HIGH);
// delay(1000)
THIS PROGRAMME WILL THE DOOR UNLOCK VIA FINGERPRINT SENSOR
PLEASE CHANGE TO ONE SKETCH AND SEND ME IN MY EMAIL : MIANISMAIL95@GMAIL.COM
