How do i combine two codes of arduino?
first code
float rpm=0;
lcd.begin(16, 2);
pinMode(sensor,INPUT_PULLUP);
lcd.setCursor(0,0);
lcd.print(" STEPS - 0");
lcd.setCursor(0,1);
lcd.print(" RPM - 0.00");
start_time=millis();
end_time=start_time+1000;
while(millis()<end_time)
if(digitalRead(sensor))
steps=steps+1;
while(digitalRead(sensor));
lcd.setCursor(9,0);
lcd.print(steps);
lcd.print(" “);
temp=steps-steps_old;
steps_old=steps;
rpm=(temp*60);
lcd.setCursor(9,1);
lcd.print(rpm);
lcd.print(” ");
This program will display the speed of motor
second code
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
delayMicroseconds(0); // approximately 50% duty cycle @ 50HZ
digitalWrite(13, HIGH);
delayMicroseconds(10000 - 0);
This program will control firing angle for triac
I have tested both programs individually and it worked.
I was wondering if if i can combine both programs together.
Can someone please help? :slight_smile:
Thank you!! Appreciate much!! :slight_smile:
The first code doesn’t even compile,
Please remember to use code tags
In your first code you have
    steps=steps+1;
   lcd.setCursor(9,0);
   lcd.print(steps);
   lcd.print("   ");
This stops the program from doing anything else for at least 1 second. Is it OK for the second program to do nothing for the same period ?
no
is there any method to combined these two code ?
I try for mix them but the program 2 not working will
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
int sensor = 11;
unsigned long start_time = 0;
unsigned long end_time = 0;
int steps=0;
float steps_old=0;
float temp=0;
float rpm=0;
pinMode(8, OUTPUT); //FOR PULSE
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
// FOR PULSE
digitalWrite(8, LOW);
delayMicroseconds(5000); // approximately 50% duty cycle @ 50HZ
digitalWrite(8, HIGH);
delayMicroseconds(10000 - 5000);
steps=steps+1;
lcd.setCursor(9,0);
lcd.print(steps);
lcd.print(" “);
steps_old=steps;
rpm=(temp*60);
lcd.setCursor(9,1);
lcd.print(rpm);
lcd.print(” ");
these will give me full wave
does not give me what I want
when I used suppurated I get correct wave
Do not cross-post
Second topic deleted
