If the same string is read by serial.read then display that it has been already entered.
Please post a complete sketch showing what you are trying to do
Do yo, for instance, need to compare 2 Strings (capital S) or 2 strings (lowercase s) ?
Read the forum guidelines to see how to properly post code.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
int count = 0;
char c;
String id;
while (Serial.available() > 0)
c = Serial.read();
count++;
id += c;
if (count == 12)
String v = "AB123456789B";
Serial.print(id);
if (id == v)
Serial.print(id);
Serial.println("First Valid Tag");
char cc = Serial.read();
if ( v == cc) {
Serial.println("Enter other id");
else if (id == "DB123456789C") {
Serial.println("Second valid tag");
Serial.println("no tag");
count = 0;
id = "";
Please follow the advice given in the link below when posting code. Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
This will never be equal:
if ( v == cc) {
V is type String and cc is a single char.
It looks like you want two 12-character ID's entered in order.
String id;
const char *IDList[] = {"AB123456789B", "DB123456789C"};
int IDCount = 0;
char c = Serial.read();
id += c;
if (id.length() == 12)
// We have a complete tag ID.
// Check it against the current ID
if (id == IDList[IDCount])
Serial.print("Valid match for ");
Serial.println(IDList[IDCount]);
IDCount++;
id = "";
if (IDCount == 2)
// All ID's matched. What do you want to do?
Serial.println("All tags matched.");
IDCount = 0;
// Does not match
Serial.print(id);
Serial.print(" is not a match for ");
id = "";
