Guys i need help XD
I'm assembling an array with 5 MAX 7221 with Arduino, the Code provides a series of animations can be selected via a button, the problem is that I have no idea how I should connect the button sull'ARDUINO. Can you help me?
Here's the code I'm using.
thanks
//We always have to include the library
//File created for DragonCon 2011
#include "LedControl.h"
#include <Button.h>
// Change these pin numbers as neccessary
char Pin_dataIn = 9; // data in pin
char Pin_clk = 7; // clk pin
char Pin_load = 8; // load pin
char numOfMatrices = 5; // increment this for each 7219 you've got connected. I imagine this will be 5.
int brightness = 8; // set the brightness of the LEDs. Use a value between 0 - 15
char screen[40];
char screenSize = 40;
char textBuffer[3][100];
char textBufferSize[3] = {90,51,66};
int pointer = 0;
long nextFrameTime = 0;
int effectType = 0;
int framePointer = 0;
// init led control object
LedControl lc = LedControl(Pin_dataIn,Pin_clk,Pin_load,numOfMatrices);
Button button = Button(4, HIGH);
/* we always wait a bit between updates of the display */
unsigned int delayTime=40;
The MAX72XX is in power-saving mode on startup,
we have to do a wakeup call
for(int index=0;index<lc.getDeviceCount(); index++) {
lc.shutdown(index,false);
/* Set the brightness to a medium values */
lc.setIntensity(index,brightness);
/* and clear the display */
lc.clearDisplay(index);
randomSeed(analogRead(0));
button.setHoldDelay(3000);
loadTextBuffers();
button.listen();
if(button.onRelease()) {
effectType++;
if(effectType > 10) {
effectType = 0;
pointer = 0;
framePointer = 0;
long current = millis();
if(current > nextFrameTime) {
nextFrameTime = current + delayTime;
switch(effectType) {
case 0:
effectThinLine();
case 1:
effectRandomPixels();
case 2:
effectScanner();
case 3:
effectBlinkingEyes();
case 4:
effectTextScroll(0);
case 5:
effectTextScroll(1);
case 6:
effectTextScroll(2);
case 7:
effectArrows();
case 8:
effectECG();
case 9:
effectScannerHorizontal();
default:
effectBlank();
display();
void display() {
unsigned char matrixID = 0;
// screen now holds the updated values
// write to the matrix
for(unsigned char i = 0; i < numOfMatrices; i++) {
for(int j = 0; j < 8; j++) {
int k = j;
k += 1;
if(k > 7) {
k = 0;
char matrixID = 4 - i;
//matrixID = 0;
char bufferData = screen[((7-k)+(i*8))];
char rowData = (bufferData >> 1) | (bufferData << 7);
lc.setRow(matrixID,j,rowData);
for(unsigned char i = 0; i < screenSize; i++) {
matrixID = floor(i/8);
lc.setColumn(matrixID,i,screen[i]);
for(unsigned char j = 0; j < 8; j++) {
//matrixID = 0;
lc.setColumn(matrixID,j,screen[(j+(i*8))]);
void scrollFromRight(int bufferNum) {
int offset = screenSize - pointer;
screen[i] = getBufferData(bufferNum, i-offset);
void scrollFromLeft(int bufferNum) {
int offset = (0-textBufferSize[bufferNum]) + pointer;
void staticCenter(int bufferNum) {
int offset = round((screenSize - textBufferSize[bufferNum]) / 2);
char getBufferData(int bufferNum, int pos) {
char tmp;
if((pos >= 0) && ((pos) < textBufferSize[bufferNum])) {
return textBuffer[bufferNum][pos];
return B00000000;
void effectThinLine() {
for(int i = 0; i < 40; i++) {
screen[i] = B00011000;
void effectRandomPixels() {
screen[i] = random(256);
void effectScanner() {
screen[i] = B00000000;
int tmpPointer = framePointer;
if(framePointer > 37) {
tmpPointer = 37 - (framePointer - 37);
for(int i = tmpPointer; i < (tmpPointer+3); i++) {
screen[i] = B11111111;
framePointer++;
if(framePointer > 73) {
framePointer = 0;
void effectScannerHorizontal() {
if(framePointer > 6) {
tmpPointer = 6 - (framePointer - 6);
screen[i] = B10000000 >> (tmpPointer + 1);
display();
delay(50);
framePointer++;
if(framePointer > 11) {
framePointer = 0;
void effectBlank() {
void effectTextScroll(char bufferNum) {
pointer += 1;
if(pointer > (textBufferSize[bufferNum] + screenSize)) {
pointer = 0;
scrollFromRight(bufferNum);
void effectBlinkingEyes() {
if(random(50) == 0) {
