i come accross this code and i think its gonna help me i have the sensors
VCNL4010 and a Adafruit Seesaw
and im gonna try and connect it to the Zumo bot on Arduino Uno
but there is no wireing diagram im noy sure what pins on the VCNL4010 go to the seesaw pins 11,10,14,15
can anyoone help here
#include <ZumoBuzzer.h>
#include <ZumoMotors.h>
#include <Pushbutton.h>
#include <QTRSensors.h>
#include <ZumoReflectanceSensorArray.h>
#include <Adafruit_seesaw.h>
#include <seesaw_neopixel.h>
class IRProximity {
Adafruit_seesaw ss;
int sensor;
int wait;
unsigned long previousMillis;
public:
IRProximity(int waitTime) {
wait = waitTime;
previousMillis = 0;
void attachPin(int pin, Adafruit_seesaw seesaw) {
ss = seesaw;
sensor = pin;
ss.pinMode(sensor, INPUT_PULLUP);
boolean getBoolean() {
if (!ss.digitalRead(sensor)) {
if (millis()-previousMillis >= wait) return true;
previousMillis = millis();
return false;
Adafruit_seesaw ss;
#define LED 13
#define BAT A1
// this might need to be tuned for different lighting conditions, surfaces, etc.
#define QTR_THRESHOLD 400 // microseconds
// these might need to be tuned for different motor types
#define REVERSE_SPEED 300 // 0 is stopped, 400 is full speed
#define TURN_SPEED 400
#define FORWARD_SPEED 200
#define FULL_SPEED 400
#define REVERSE_DURATION 150 // ms
#define TURN_DURATION 200 // ms
ZumoBuzzer buzzer;
ZumoMotors motors;
Pushbutton button(ZUMO_BUTTON); // pushbutton on pin 12
#define NUM_SENSORS 6
unsigned int sensor_values[NUM_SENSORS];
ZumoReflectanceSensorArray sensors(QTR_NO_EMITTER_PIN);
#define FRONT_DURATION 10 //ms
#define SIDE_DURATION 25 //ms
IRProximity frontLeft(FRONT_DURATION);
IRProximity frontRight(FRONT_DURATION);
IRProximity left(SIDE_DURATION);
IRProximity right(SIDE_DURATION);
#define TURN_TIME 180 //ms
boolean rTurn = false;
boolean lTurn = false;
unsigned long previousMillis = 0;
void waitForButtonAndCountDown()
digitalWrite(LED, HIGH);
button.waitForButton();
digitalWrite(LED, LOW);
// play audible countdown
for (int i = 0; i < 3; i++)
buzzer.playNote(NOTE_G(3), 200, 15);
buzzer.playNote(NOTE_G(4), 500, 15);
// uncomment if necessary to correct motor directions
//motors.flipLeftMotor(true);
//motors.flipRightMotor(true);
if(!ss.begin()){
while(1);
frontLeft.attachPin(11, ss);
frontRight.attachPin(10, ss);
left.attachPin(14, ss);
right.attachPin(15, ss);
pinMode(LED, OUTPUT);
waitForButtonAndCountDown();
unsigned int batteryVoltage = analogRead(BAT) * 5000L * 3/2 / 1023;
digitalWrite(LED, batteryVoltage < 4500);
if (button.isPressed())
// if button is pressed, stop and wait for another press to go again
motors.setSpeeds(0, 0);
button.waitForRelease();
sensors.read(sensor_values);
if (sensor_values[0] < QTR_THRESHOLD)
// if leftmost sensor detects line, reverse and turn to the right
motors.setSpeeds(-REVERSE_SPEED, -REVERSE_SPEED);
delay(REVERSE_DURATION);
motors.setSpeeds(TURN_SPEED, -TURN_SPEED);
delay(TURN_DURATION);
motors.setSpeeds(FORWARD_SPEED, FORWARD_SPEED);
else if (sensor_values[5] < QTR_THRESHOLD)
// if rightmost sensor detects line, reverse and turn to the left
motors.setSpeeds(-TURN_SPEED, TURN_SPEED);
// otherwise, track and move
if (rTurn) {
motors.setSpeeds(FULL_SPEED, -FULL_SPEED);
if (millis() - previousMillis > TURN_TIME) {
rTurn = false;
} else if (lTurn) {
motors.setSpeeds(-FULL_SPEED, FULL_SPEED);
lTurn = false;
rTurn = right.getBoolean();
lTurn = left.getBoolean();
if (frontLeft.getBoolean() && frontRight.getBoolean()) {
motors.setSpeeds(FULL_SPEED, FULL_SPEED);
} else if (frontLeft.getBoolean()) {
} else if (frontRight.getBoolean()) {
