Hi everybody,
I am working on a (rather hasty) project with EL Wires (Light emitting wires), which work with a couple of 100V/2000Hz/250mA inverters. (datasheet of the cables: http://www.elam-lytec.com/pdf/04S_common.pdf, specification of the inverters: http://www.kitelight.nl/var/images/KD15.JPG)
I need to control 72 separate pieces of this wire stuff, with a total length of about 30 meters. These pieces will form 3 digital characters (23 pieces per character) in a distinct font (regular digits with 7 bars would have been so much easier... :-/ ).
Therefor I want to keep the circuits as simple as possible. This is a simplified sketch of what I think it should be like. Each inverter can handle wires between 10-20m, so I choose to use three, makes sense when you're building 3 big characters anyway ;)
Question 1: How can I do this? How do I get the 5v from Arduino to switch 100v cables? I am guessing getting 72 TIP120's or something alike, or is there a better solution? Maybe some way cheaper solution with ICs that can handle these high voltages and do the same? I can imagine there has to be something which has 1 pin for the incoming curent, 8 for the incoming signals and 8 for the outgoing signals. or something alike, does that make sense?) I am not looking forward to solder 72 triacs.. ;) Anyone who has done something like this before?
Question 2: In order to get the required number of outputs I am using planning on using four 74HC595's (+ 1 regular digital pin) to create a three 8 * 3 grids (24 pins where I need 23 on each), which theoretically works fine to control leds, but have no idea if this can handle 72 wires. Should I go for this solution or maybe use a proper (led drivers?) ICs instead? If so, which ones?
I have put myself in a situation which makes me feel completely noobish once more, great!
[u]ANY HELP OR SUGGESTIONS GREATLY APPRECIATED!![/u]
