How do I control MCP41010 using ESP32
It is supposed to be a really simple task, but im running into an error:
E (23) gpio: GPIO can only be used as input mode
Here is the code I have used: (I am not even using GPIO 23, wtf is going on T_T)
#include <SPI.h>
const int CS_PIN = 35; // Chip Select pin
const int MOSI_PIN = 21; // Master Out Slave In
const int SCK_PIN = 18; // Clock pin
const int MISO_PIN = 19;
const int dummypin = 23;
//00010001 in hexadecimal this is taken from datasheet
#define CMD_WRITE 0x11
  SPI.begin(SCK_PIN, MISO_PIN, MOSI_PIN, CS_PIN);
  pinMode(dummypin, INPUT);
  pinMode(CS_PIN, OUTPUT);
  // Set CS high
  digitalWrite(CS_PIN, HIGH);
  setPotentiometerValue(0); // Value range is 0-255
// Function to set potentiometer value
void setPotentiometerValue(uint8_t value) {
  // Bring CS low to select the MCP41010
  digitalWrite(CS_PIN, LOW);
  SPI.transfer(CMD_WRITE); // Command byte
  SPI.transfer(value); // to set pot value
  // Bring CS high to send the data (ig)
Where am I going wrong T_T, I am not even using GPIO23
Here is the datasheet: Single/Dual Digital Potentiometer with SPI Interface (microchip.com)
You can check the answers here about the error message you are seeing.
Is this upside down? Setting a pin after using it?
I think this is "error #23"... and has to do with other GPIO pins (reserved?)
https://docs.espressif.com/projects/esp-idf/en/latest/esp32/api-reference/peripherals/gpio.html
ah shit thanks, i think i need to change that
thanks for the reply, will check that out
any particular reason not to use the default ESP32 VSPI pins?
MOSI: 23
MISO: 19
SCK: 18
SS: 5
I am already using those pins for something else and they are soldered inplace, i do not want to remove the soldering and rework again
