How do I convert Arduino data into waveform ?
Hi:
I am looking for way to visually display data from a sensor onto PC/laptop screen.
So far I have been able to get Arduino board up and running.
Also I am able to open serial monitor and can see data in numerical form within serial monitor.
However, I would like to make some decisions based on the waveform of the data. To do this I want to visually see in the form of a waveform.
Since my programming skills (speciallly OOP) skill are very limited, I am looking for easy way to display data as waveform.
Any ideas are appreciated.
My understanding is that Arduino with Processing will be much simpler than other combinations.
  1. Arduino + Python code
  2. Arduino + Processing code.
For my case, 2) should be easier than 1), right ?
Regards,
-Umakant
yes for sure processing.
have a look at the oscilliscope example, it graphs an analog value over time.
Thanks bill-- that gives pointer in which direction to proceed.
You mean there is an oscilloscope example in Arduino IDE ? (or you mean look in Processing examples ?)
Regards
