How do I convert it to switch case?
const int red = 5;
const int green = 6;
const int blue = 9;
int lastState = LOW;
int r = 0; //red
int g = 0; //green
int b = 0; //blue
int dir = 0;
int led = 11;
int b1, b2; // buttons
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(red, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(blue, OUTPUT);
  for (int i = 11; i <= 18; i++) {
    pinMode(i, OUTPUT);
  b1 = digitalRead(2);
  b2 = digitalRead(3);
  if (b1 == HIGH) {
    dir = 1;
    dir = 0;
  digitalWrite(led, LOW);
  if (dir == 1 && led < 18) {
    led++;
  } else if (dir == 1 && led == 18) {
    led = 11;
  digitalWrite(led, HIGH);
  delay(200);
  if(b2 == HIGH && lastState == LOW) {
    function(led, 1);
  if (b2 == HIGH && lastState == HIGH) {
    function(led, 0);
  lastState = b2;
void function(int pin, int sw) {
  if(pin == 11 && sw == 1) {
    digitalWrite(red, HIGH);
  } else if (pin == 11 && sw == 0) {
    digitalWrite(red, LOW);
  if (pin == 12) {
     if (pin == 12 && sw == 1 || sw == 0){
       r = r +5;
     }else if (r == 255){
      r = 0;
    analogWrite(red, r);
  if (pin == 13 && sw == 0) {
    digitalWrite(green, HIGH);
  } else if (pin == 13 && sw == 1) {
    digitalWrite(green, LOW);
  } if (pin == 14) {
    if (pin == 14 && sw == 1 || sw == 0) {
      g = g+5;
    } else if (g = 255) {
      g = 0;
    analogWrite(green, g);
  if(pin == 15 && sw == 0) {
    digitalWrite(blue, HIGH);
  } else if (pin == 15 && sw == 1) {
    digitalWrite(blue, LOW);
  } if (pin == 16) {
    if (pin == 16 && sw == 1 || sw == 0) {
      b = b+5;
    } else if (b == 255) {
      b = 0;
    analogWrite(blue, b);
  if(pin == 17) {
    analogWrite(red, 255);
    analogWrite(green, 255);
    analogWrite(blue, 255);
  } else if (pin == 18) {
    analogWrite(red, 0);
    analogWrite(green, 0);
    analogWrite(blue, 0);
Hi I just want to make it shorter is it possible to make it shorter by using switch case in void function() {
Why don't you give it a try?
switch(pin) {
   case 11:
   case 12:
Would be good to declare pin names....
