How do i convert my delay into millis
int led = PB4;
int ip = PB2;
int counter = 0;
static int prevState = 4 ;
static int delay_flag = 0;
const uint16_t t1_load = 0;
const uint16_t t1_comp = 62500;
 DDRB |= (1 << led); //setting led an output
 DDRB &= ~(1 << ip);//ir sensor as input
 PORTB |= (1 << ip);  //setting 1 thus enabling pull up resistor
 //reset timer control reg A
 TCCR1A = 0;
 //set prescaler of 256
 TCCR1B |= (1 << CS12);
 TCCR1B &= ~(1 << CS11);
 TCCR1B &= ~(1 << CS10);
 //reset timer 1 and set compare values
 TCNT1 = t1_load;
 OCR1A = t1_comp;
 //enable timer compare interrupts
 TIMSK1 = (1 << OCIE1A);
 //enable global interrupts
 sei();
 check();
 if(delay_flag == 1){
   PORTB |= (1 << led);
   delay(3000);
   PORTB &= ~(1 << led);
   delay_flag = 0;
   counter = 0;
void failsafe(){
 counter =0 ;
//4 not detected(1) 0 detected (0)
void check() {
PORTB &= ~(1 << led);   //led low;
 int currState = (PINB & B00000100);
 Serial.print(currState);
 if (prevState == 0 && currState == 4 )
   delay(3000);
   counter = 0;
  prevState = currState;
ISR(TIMER1_COMPA_vect) {
   counter = counter + 1;
   if(counter == 20){
       delay_flag = 1;
       TCNT1 = t1_load;
See the blink without delay example...
File -> Examples -> 02. Digital -> Blink Without Delay
i tried using the millis function , but it still isnt working
void check() {
long currTime = millis();
if(currTime - prevTime >= interval){
counter = 0;
prevTime = currTime ;
Please read the sticky at the top of the forum: "Read this before posting a programming question ..."
If you follow the forum guidelines and then ask your question using complete sentences, you are likely to get more guidance.
Have a look at how millis() is used to manage timing without blocking in Several Things at a Time.
And see Using millis() for timing. A beginners guide if you need more explanation.
...R
Probably because you start with...
If every time you call function check() you turn the led off, what do you think the overall effect on the led is likely to be?
Also this code...
...seems to be checking for a state change.
If your millis() code is inside that if it is not going to work well. Millis() testing code needs to be where it executes continuously from loop().
